Hi,
I just installed win_ros fuerte. I have been running electric on windows without any problems. A linux box acts as the Master and the windows machine broadcasts messages to the linux box. However, with win_ros fuerte I am unable to get my messages across to the linux box. Win_ros will run fine with the ROS_MASTER_URI set to the ip address of the linux machine. Also, when I start broadcasting messages from windows I can see the message name when I type "rostopic list" on both the windows and the linux sides. However, I can only echo the messages on the windows side. It seems like there is enough connectivity between the machines to see that a message started, but not enough to actually pass the data. The same thing happens when windows is the "master". Ros_wtf just gives an unknown network error.
I realize this is a vague question -- I'm mainly interested in knowing if anyone has successfully talked between windows and linux with win_ros fuerte.
Thanks! Mark
Originally posted by MarkC on ROS Answers with karma: 21 on 2012-06-22
Looks like it is the usual multi-machine problem. If so, it's not directly related to winros, just make sure you get your ip/hostname settings exported correctly.
Seing as this question comes up often with windows-linux ros connections, I've added some information on the WinRoS FAQ. A direct link to the issue in detail is here.
Originally posted by Daniel Stonier with karma: 3170 on 2012-06-24
I can confirm that I've successfully sent data from a windows computer to Linux using fuerte. I followed the instructions for setting up the SDK on Windows 7 and then built a ROS node using Visual Studio. I was able to send both data and video to a Linux computer over the network (with roscore running on the Linux box). Other than changing ROS_MASTER_URI, the only other thing I can remember that I did was to add entries to the hosts file on both the Windows and Linux computers (to make sure each computer had the correct IP address of the other).
Originally posted by Jon with karma: 115 on 2012-06-23
