Hello,
I am currently working on using move_arm (and associated packages) with our 7 dof manipulator. I am using diamondback. I used pr2_arm_navigation as a template and have generated all the appropriate config/launch files. The problem is when send a move_arm_joint_goal often I get an error from the trajectory_filter_server:
ERROR: Joint name r_base_RollJoint not found in raw joint state message
ERROR: Filter chain failed to process trajectory
ERROR: Service call to filter trajectory failed.
This happens quite often, about half the time, but when it doesn't happen the goal is reached. I am not sure why trajectory_filter_server is not finding this joint in the raw joint state message only sometimes. Any advice is greatly appreciated.
Other information:
trajectory_filter_server launch:
<launch>
    <node pkg="trajectory_filter_server" name="trajectory_filter" type="trajectory_filter_server" output="screen">
        <rosparam command="load" file="$(find TRACBot_arm_navigation)/config/joint_limits.yaml"/>
        <rosparam command="load" file="$(find TRACBot_arm_navigation)/config/filters.yaml"/>
    <remap from="robot_description" to="robot_description" />
    <remap from="collision_map" to="collision_map_occ" />
    <remap from="collision_map_update" to="collision_map_occ_update" />
    <param name="refresh_interval_collision_map" type="double" value="5.0" />
    <param name="refresh_interval_kinematic_state" type="double" value="1.0" />
    <param name="bounding_planes" type="string" value="0 0 1 -0.01" />
    <param name="compute_contacts" type="bool" value="false" />
    <param name="pointcloud_padd" type="double" value="0.00" />
    <rosparam command="load" file="$(find TRACBot_arm_navigation)/config/robot_padding.yaml" />
    </node>
</launch>
filter config file:
service_type: FilterJointTrajectoryWithConstraints
filter_chain:
       type: UnNormalizeFilterJointTrajectoryWithConstraints
      type: CubicSplineShortCutterFilterJointTrajectoryWithConstraints
      params: {discretization: 0.01}
Thanks,
Jonathan
Originally posted by Jonathan Realmuto on ROS Answers with karma: 26 on 2011-07-08
Comment by arebgun on 2011-07-08:
How are you publishing your joint states, i.e. how /joint_states topic is being populated?
Thank you Martin.
I figured out the problem. I was publishing two different joint state messages - one for my 7 dof manipulator and one for my pan/tilt camera mount. What was happening is about half the time the move_arm functions were receiving the correct 7 dof joint states and the other half the time received the 2 dof pan/tilt joint states. All joint states must be published in the same message.
The reason I used two different messages is that the pan/tilt mechanism was controlled using ptz-gazebo plugin and the 7 dof arm uses robot_mechanism_controller. I think the best thing to do is change the pt2-gazebo plugin to another robot_mechanism_controller.
Originally posted by Jonathan Realmuto with karma: 26 on 2011-07-19
Comment by Sachin Chitta on 2011-07-20:
Thanks for the ticket, Martin. We will look into it.
Comment by Martin Günther on 2011-07-19:
Okay, ticket created: https://code.ros.org/trac/wg-ros-pkg/ticket/5136
I thought so. Still, I believe that this is not the best behaviour of trajectory_filter_server. It should be possible to send joint states from different nodes. Maybe @Sachin Chitta could comment on that? Or maybe we should file a ticket?
