base_link
(or base_footprint
depending on your configuration) should go at the rotational center of the robot, i.e. the point about which the diff drive robot can spin-in-place. This assumes that base_link
is the frame you will be using to command velocities relative to.
I don't know if this is actually explicitly stated anywhere, but it's how I've always configured move_base.
Note that you can always make another frame called "geometric_center" or something similar and publish a transform between that and base_link
if you would prefer other transforms relative to the geometric center of the robot instead of the center of rotation.
Originally posted by Eric Perko with karma: 8406 on 2011-06-13
Comment by eitan on 2011-06-13:
Good point on this never being documented. I added a note in this tutorial: http://www.ros.org/wiki/navigation/Tutorials/RobotSetup/TF mentioning it.
