11
I've been doing a lot of reading lately about Subsumption Architecture and there are a few different ways people seem to advocate.
For instance some people use a global "flag" variable to have a task take control. Others use the endTimeSlice() and allow the arbiter to really choose. And I think this is correct.
I have this small section of RobotC code that I'm working on for a line following robot but am not sure I am doing it right as currently the track method will always take over the find method. The correct flow should be that find should guide the robot to the line using a spiral path to find the line. Once the line is found track should take over.
task evade(){
    if(SensorValue(forwardSonarSensor) > threshold){
            //box the obstruction
task find(){
    if(SensorValue(lightSensor) > threshold){
            //spiral the robot
task track(){
    if(SensorValue(lightSensor) < threshold){
            //go straight
    }else{
                //execute turns to follow the line
task main(){
    while(true){
        StartTask(evade,9);
        StartTask(track,8);
        StartTask(find,7);
        wait1Msec(250);
I've just used some comments here rather than the actual code to keep it brief. Are my if statements not good enough as conditions because when the robot is off the line, track() takes over. Is this due to the else statement within track? If so, how to have track() perform turns when it looses the line without taking over from forage at the start of the program?
    $\begingroup$ The numbers you give in StartTask, are they the priority of the task? Is 9 going to be the highest priority? In that case, shouldn't find have more priority than track? In fact, the condition of find and the else condition of track are the same. So, as a human, if the sensor value is bigger than threshold, what would you do? Go on spiral or turn to adjust the line? $\endgroup$
    – Shahbaz
    Commented Nov 8, 2012 at 14:05
  • $\begingroup$ I know what subsumption architecture is, and I'm sure your robots should have different hardware modules taking responsibility for low level computational tasks. And that the code should actually be absorbing the signal rather than just listening for a conditional state. So shouldn't you be passing the signal into another piece of hardware ? Now my problem is I have an two Arduinos and I want Arduino A to subsume or inhibit a signal from Arduino B . Does anyone have any idea how this is done? As I can wire Arduino A to send a signal to Arduino B but I'm unsure how to subsume or inhibit the sig $\endgroup$ Commented Dec 23, 2017 at 14:34
7
With Subsumption Architecture, you should carefully design your behaviors in such a way that if you assign task T priority n, then T should be what the robot should do if all tasks with higher priority than n are ignored.
Let's order your example tasks, then figure out a way to implement it. Your tasks are evade, find and track.
In general you would want the robot to track a line. However, if it couldn't detect the line, then it should try to find it. Above all, it should evade obstacles. This gives us the following ordering:
  • Highest priority: evade
  • Then: find
  • Then: track
The reason find has higher priority than track is that, as I mentioned above, you would track only if evade and find are unnecessary. If you put find below track, that means you start tracking if there is no obstacle, even if you are not on the line.
Now let's look at your implementation:
task find(){
            //spiral the robot
task track(){
            //go straight
    }else{
Remember that we gave find a higher priority. Therefore, if the robot cannot sense the lightSensor, it will go in spiral trying to find the line. Once it does, track kicks in. As you can see, the else condition of track never happens.
While this works, the robot would move very awkwardly. There is not much you can do about it in fact, given the current build of your robot.
Although I already answered your question, but here is a simple improvement to your line tracking:
Instead of one light sensor, use two; ls_left and ls_right. Using (at least) two sensors, you can understand whether you are totally out of the track, or about to go out of the track. In the second case, you can easily turn to the proper direction and get back on track.
Your find task is similar:
task find(){
    if (SensorValue(ls_left) > threshold
        && Sensorvalue(ls_right) > threshold){
            //spiral the robot
That is, you go in spiral only if you don't sense anything at all
Your track task now becomes more efficient:
task track(){
    if (SensorValue(ls_left) < threshold
        && SensorValue(ls_right) < threshold){
            //go straight
    } else if (SensorValue(ls_left) < threshold
        && SensorValue(ls_right) > threshold){
            //turn left
    } else if (SensorValue(ls_left) > threshold
            //turn right
    } else {
            // shouldn't happen, but go on spiral anyway
Obviously, with a matrix of light sensors, you can better judge how badly you are going out of track (i.e. with what angle) and better decide how to get back on track (i.e. with what angular speed).
short answer; no you really need to do things quite a bit differently.
long incomplete answer; Let me give you some psuedo code appropriate for robotC, that puts you on a better path. First, do not use tasks - this is NOT what robotC tasks are for. They could be made to work, maybe, maybe not (and you need quite a few changes to even try).
// global variables
int distance;
int light;
main() {
   while (true) {
   distance = read_distance;
   light = read_light;
   if (task1_wantsToRun())
     task1_run();
   if (task2_wantsToRun())
     task2_run();
there is a couple of things here; priority becomes irrelevant. As nice as it seems to have tasks in robotC with priorities, they are not a good choice for subsumption implementation in my experience. For reasons like, priorities are not always honored, tasks can not be interrupted (sometimes) so when a higher priority event occurs, it is not going to react like you expect, robotC only recently became re-entrant, so things like accessing a sensor from more than 1 task may be risky (I2C timing issues), and in some cases it is not (automatically polled sensors).
You can add your own priority implementation to the above loop as you get things working, but it really is not needed for starts.
Your comment "//box the obstruction" describes a ballistic behavior. Those are a bit tricky to implement using multi-tasking. The simple loop I used makes it a lot easier, and better for starters/learning.
The other thing I will leave you with, is that subsumption while being neat and appropriate for a lot of things, is not a good way to implement what is better done traditionally. Indeed the 'evade' portion may be a good candidate for subsumption, but honestly your other task should be called 'GoOnAboutYourBusiness'. I say this because you probably do not want to change from searching to following with subsumption. Handle those with traditional programming loops. With a single sensor, - is the light sensed darker or lighter than it was last loop? if it got darker (assuming black line) keep turning the same direction, if it got lighter turn the other way, if it stayed the same, go straight. You probably need to add some PID and use a steering curve instead of just turning left and right to be smoother.
And yes, multiple sensors help. http://www.mindsensors.com/ - yeah, that's me in the movie currently (11/10/2012)
Update: actual code
I will try this out in a little while, but it compiles and illustrates what I wrote above:
#pragma config(Sensor, S1,     S_LIGHT,        sensorLightActive)
#pragma config(Sensor, S2,     S_DISTANCE,     sensorSONAR)
#pragma config(Motor,  motorB,          LEFT,          tmotorNXT, PIDControl, encoder)
#pragma config(Motor,  motorC,          RIGHT,         tmotorNXT, PIDControl, encoder)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
int distance_value, light_value;
bool evade_wantsToRun()
    return distance_value < 30;
void evade_task()
    // full stop
    motor[LEFT] = 0;
    // evade the object ballistically (ie in full control)
    // turn left, drive
    nSyncedTurnRatio = 0;
    motor[LEFT] = -20;
    Sleep(500);
    nSyncedTurnRatio = 100;
    Sleep(1000);
    // turn right, drive
    motor[LEFT] = 20;
    Sleep(500);
    Sleep(1000);
    motor[LEFT] = 20;
    Sleep(500);
    Sleep(1000);
    // turn left, resume
    motor[LEFT] = 20;
    Sleep(500);
    motor[LEFT] = 0;
void TurnBySteer(int d)
    // normalize -100 100 to 0 200
    nSyncedTurnRatio = d + 100;
typedef enum programPhase { starting, searching, following, finished };
programPhase phase = starting;
// these 'tasks' are called from a loop, thus do not need to loop themselves
void initialize()
    nSyncedTurnRatio = 50;
    nSyncedMotors = synchBC;
    motor[LEFT] = 30;       // start a spiral drive
    phase = searching;
void search()
    if (light_value < 24)
        phase = following;
int lastLight = -1;
int currentSteer = 0;
void follow()
    // if it is solid white we have lost the line and must stop
    // if lightSensors detects dark, we are on line
    // if it got lighter, we are going more off line
    // if it got darker we are headed in a good direction, slow down turn in anticipation
    // +++PID will be even smoother
    if (light_value > 64)
        motor[LEFT] = 0;
        phase = finished;
        return;
        currentSteer = 0;
    else if (light_value > lastLight)
        currentSteer += sgn(currentSteer) * 1;
    else    // implied (light_value < lastLight)
        currentSteer -= sgn(currentSteer) * 1;
    TurnBySteer(currentSteer);
bool regularProcessing_wantsToRun()
    return phase != finished;
void regularProcessing_task()
    switch (phase)
    case starting:
        initialize();
        break;
    case searching:
        search();
        break;
    case following:
        follow();
task main()
    // subsumption tasks in priority oder
    while (true)
        // read sensors once per loop
        distance_value = SensorValue[S_DISTANCE];
        light_value = SensorValue[S_LIGHT];
        if (evade_wantsToRun())
            evade_task();
        if (regularProcessing_wantsToRun())
            regularProcessing_task();
        else
            StopAllTasks();
        EndTimeSlice();     // give others a chance, but make it as short as possible
  • $\begingroup$ I agree that this problem is more easily solved with a simple loop. I don't understand why would anyone downvote this. $\endgroup$
    – Shahbaz
    Commented Nov 10, 2012 at 13:44
  • $\begingroup$ I do not want to leave the impression that it easier to solve with a simple loop, but rather the impression that it IS the correct use of subsumption to use a simple loop as one of the tasks. Whomever downgraded it has mod points, and no understanding of subsumption. You will not find that there is not a lot of people doing subsumption on an LEGO NXT (implied by using robotC), so don't expect code to be readily available to be pasted. $\endgroup$
    – Spiked3
    Commented Nov 10, 2012 at 17:54
  • $\begingroup$ Yes, I as wondering why the OP was using tasks for something as simple as subsumption. $\endgroup$ Commented Nov 10, 2012 at 19:52
  • $\begingroup$ Because it is a very very very very very common beginner mistake with robotC - to try and use tasks for everything. I wish they would move it to an advanced only area. $\endgroup$
    – Spiked3
    Commented Nov 13, 2012 at 2:46
