How do you calculate or update the position of a differential drive robot with incremental sensors?
There is one incremental sensor attatched to each of the two differential wheels. Both sensors determine the distance $\Delta left$ resp. $\Delta right$ their wheel has rolled during a known time $\Delta t$.
First, let's assume the center between both wheels marks the position of the robot. In this case, one could calculate the position as:
$$ x = \frac{x_{left}+x_{right}}{2} \\ y = \frac{y_{left}+y_{right}}{2} $$
"Deriving" those equations under the assumption that both wheels rolled in a straight line (which should be approximately correct for small distances) I get:
$$ \frac{\Delta x}{\Delta t} = \frac{1}{2}\left( \frac{\Delta left}{\Delta t} + \frac{\Delta right}{\Delta t}\right)cos(\theta) \\ \frac{\Delta y}{\Delta t} = \frac{1}{2}\left( \frac{\Delta left}{\Delta t} + \frac{\Delta right}{\Delta t}\right)sin(\theta) $$
Where $\theta$ is the angle of orientation of the robot. For the change of this angle I found the equation
$$ \frac{\Delta \theta}{\Delta t} = \frac{1}{w} \left( \frac{\Delta left}{\Delta t} - \frac{\Delta right}{\Delta t}\right) $$
Where $w$ is the distance between both wheels.
Because $\Delta x$ and $\Delta y$ depend on $\theta$, I wonder whether I should first calculate the new $\theta$ by adding $\Delta \theta$ or if I should rather use the "old" $\theta$ ? Is there any reason to use one over the other?
Then, let's now assume the center between both wheels does not mark the position of the robot. Instead I want to use a point which marks the geometric center of the robot's bounding box. Then $x$ and $y$ change to:
$$ x = \frac{x_{left}+x_{right}}{2} + l\, cos(\theta)\\ y = \frac{y_{left}+y_{right}}{2} + l\, sin(\theta) $$
"Deriving" the first gives:
$$ \frac{\Delta x}{\Delta t} = \frac{1}{2}\left( \frac{\Delta left}{\Delta t} + \frac{\Delta right}{\Delta t}\right)cos(\theta) - l\,sin(\theta)\,\frac{\Delta \theta}{\Delta t} $$
Now there is a dependance on $\Delta \theta$. Is this a reason to use the "new" $\theta$ ?
Is there any better method to do simulatenous update of position and orientation? May be using complex numbers (same approach as with quaternions in 3D?) or homogeneous coordinates?
