Gazebo Answers logo
I have a sdf file where I put Gazebo IMU plugin. The gazebo topic is ~/turtlebot/rack/imu_sensor/imu . How can I create a ROS2 node that subscribes to that Gazebo topic?
Originally posted by tasuminagorashi on Gazebo Answers with karma: 3 on 2020-06-10
Gazebo Answers logo
Hello,
you should:
  • create a gazebo::transport::Node to subscribe the Gazebo topic
  • create a ROS 2 node and create the gith publisher.
  • In the callback you need to fill the ROS 2 message with the Gazebo IMU message.
Here you can a find a snippet of how to implement this idea.
gazebo_ros::Node::SharedPtr ros_node;
rclcpp::Publisher<sensor_msgs::msg::Imu>::SharedPtr imu_pub;
gazebo::transport::NodePtr gz_node;
// Function is called everytime a message is received.
void cb(ConstImuPtr &_msg)
  gazebo_msgs::msg::IMU imu_msg;
 // fill imu_msg message based on _msg
  imu_pub->publish(imu_msg);
int main(int argc, char ** argv)
  // Load gazebo
  gazebo::client::setup(argc, argv);
  if (!rclcpp::is_initialized()) {
    rclcpp::init(argc, argv);
    ros_node = gazebo_ros::Node::Get();
  } else {
  imu_pub = ros_node->create_publisher<sensor_msgs::msg::Imu>("/turtlebot/rack/imu_sensor/imu", rclcpp::SensorDataQoS(rclcpp::KeepLast(1)));
  // Gazebo transport
  gz_node = gazebo::transport::NodePtr(new gazebo::transport::Node());
  gz_node->Init();
  // Listen to Gazebo world_stats topic
  gazebo::transport::SubscriberPtr sub = gz_node->Subscribe("~/turtlebot/rack/imu_sensor/imu", cb);
  while (true)
    gazebo::common::Time::MSleep(10);
  // Make sure to shut everything down.
  gazebo::client::shutdown();
Originally posted by ahcorde with karma: 281 on 2020-06-22
