Gazebo Answers logo
I've had ROS and Gazebo working fine (Hydro and Gazebo 1.9 on Ubuntu 12.04). Today I installed DRCsim, and now when I try ROSlaunching (or ROSrun) a gazebo_ros package I get the following error:
[gazebo-2] process has died [pid 10651, exit code 127, cmd /opt/ros/hydro/lib/gazebo_ros/gzserver worlds/willowgarage.world __name:=gazebo __log:=/home/nbanyk/.ros/log/ebba1d2e-1c34-11e4-9f03-00216a935c82/gazebo-2.log]. log file: /home/nbanyk/.ros/log/ebba1d2e-1c34-11e4-9f03-00216a935c82/gazebo-2*.log
[gazebo_gui-3] process has died [pid 10656, exit code 127, cmd /opt/ros/hydro/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/nbanyk/.ros/log/ebba1d2e-1c34-11e4-9f03-00216a935c82/gazebo_gui-3.log]. log file: /home/nbanyk/.ros/log/ebba1d2e-1c34-11e4-9f03-00216a935c82/gazebo_gui-3*.log
Currently in my .bashrc file I have the following (bottom two lines were commented because I was troubleshooting to see if that would help): source /opt/ros/hydro/setup.bash source ~/catkin_ws/devel/setup.bash export GAZEBO_MODEL_PATH=/home/user/catkin_ws/src/ export EDITOR='nano -w' export GAZEBO_RESOURCE_PATH=/usr/share/gazebo-1.9:/usr/share/gazebo_models:~/catkin_ws/src source /usr/share/drcsim/setup.sh source /usr/share/gazebo/setup.sh
The interesting thing is that roslaunching the drcsim_gazebo package does work, for example: roslaunch drcsim_gazebo atlas_drc_vehicle_fire_hose.launch
I saw other related questions on this forum and have tried killing all gzserver's that are running.
Thanks in advance
Originally posted by nbanyk on Gazebo Answers with karma: 104 on 2014-08-04
Comment by nbanyk on 2014-08-05:
also getting this error: gzserver: symbol lookup error: /opt/ros/hydro/lib/libgazebo_ros_paths_plugin.so: undefined symbol: _ZN3ros7package10getPluginsERKSsS2_RSt6vectorISsSaISsEE gzclient: symbol lookup error: /opt/ros/hydro/lib/libgazebo_ros_paths_plugin.so: undefined symbol: _ZN3ros7package10getPluginsERKSsS2_RSt6vectorISsSaISsEE /opt/ros/hydro/lib/gazebo_ros/gazebo: 25: kill: invalid signal number or name: SIGINT
maybe this will get resolved here: https://bitbucket.org/osrf/gazebo/issue/1222/latest-debian-update-breaks-ros-hydro
Gazebo Answers logo
It was a problem with ROS ABI, it should be fixed.
The reference for the problem is: https://bitbucket.org/osrf/gazebo/issue/1222/latest-debian-update-breaks-ros-hydro
Originally posted by Jose Luis Rivero with karma: 1485 on 2014-08-05
Comment by nbanyk on 2014-08-06:
thanks, that fixed it!
