Gazebo Answers logo
I'd like to use Atlas in Gazebo with ROS Hydro and Ubuntu 12.04. I have gazebo-current 2.2.1-1 installed from debian and Hydro installed from debian. Next I tried to install DRCSim from source loosely following the Groovy instructions by making a new catkin workspace and cloning
hg clone https://bitbucket.org/osrf/osrf-common
hg clone https://bitbucket.org/osrf/sandia-hand
hg clone https://bitbucket.org/osrf/drcsim
When I compile, I get the error:
/home/dave/ros/ws_atlas/src/drcsim/drcsim_gazebo_ros_plugins/src/IRobotHandPlugin.cpp: In member function ‘void IRobotHandPlugin::UpdatePIDControl(double)’: /home/dave/ros/ws_atlas/src/drcsim/drcsim_gazebo_ros_plugins/src/IRobotHandPlugin.cpp:284:32: error: ‘class gazebo::physics::Joint’ has no member named ‘SetUpperLimit’ /home/dave/ros/ws_atlas/src/drcsim/drcsim_gazebo_ros_plugins/src/IRobotHandPlugin.cpp: In member function ‘void IRobotHandPlugin::SetJointSpringDamper()’: /home/dave/ros/ws_atlas/src/drcsim/drcsim_gazebo_ros_plugins/src/IRobotHandPlugin.cpp:649:15: error: ‘class gazebo::physics::Joint’ has no member named ‘SetStiffnessDamping’ /home/dave/ros/ws_atlas/src/drcsim/drcsim_gazebo_ros_plugins/src/IRobotHandPlugin.cpp:666:15: error: ‘class gazebo::physics::Joint’ has no member named ‘SetStiffnessDamping’ /home/dave/ros/ws_atlas/src/drcsim/drcsim_gazebo_ros_plugins/src/IRobotHandPlugin.cpp:679:12: error: ‘class gazebo::physics::Joint’ has no member named ‘SetStiffnessDamping’ /home/dave/ros/ws_atlas/src/drcsim/drcsim_gazebo_ros_plugins/src/IRobotHandPlugin.cpp:693:12: error: ‘class gazebo::physics::Joint’ has no member named ‘SetStiffnessDamping’ make[2]: ** [drcsim/drcsim_gazebo_ros_plugins/CMakeFiles/IRobotHandPlugin.dir/src/IRobotHandPlugin.cpp.o] Error 1 make[1]: ** [drcsim/drcsim_gazebo_ros_plugins/CMakeFiles/IRobotHandPlugin.dir/all] Error 2
It seems its looking for a different version of Gazebo?
Thanks!
Update:
I'm now on default branch for Gazebo and am compiling from source. While running make I get:
/home/dave/ros/ws_gazebo/gazebo/interfaces/player/player.h:22:38: fatal error: libplayercore/playercore.h: No such file or directory
I have libplayercore3.0-dev installed, not sure whats going on.
Update:
There does not appear to be a -I/usr/include/player3.0 when I compile. I do have the file:
/usr/include/player-3.0/libplayercore/playercore.h
The compile flags are:
cd /home/dave/ros/ws_gazebo/gazebo/build/gazebo/gui && /usr/bin/c++   -Dgazebo_gui_EXPORTS -DLIBBULLET_VERSION=0.0 -DQT_GUI_LIB -DQT_CORE_LIB -DQT_NO_DEBUG -g -O2 -mssse3 -msse3 -mfpmath=sse -msse -msse2  -Wall -Wextra -Wno-long-long
-Wno-unused-value -Wno-unused-value -Wno-unused-value -Wno-unused-value -Wfloat-equal -Wshadow -Winit-self -Wswitch-default -Wmissing-include-dirs -pedantic -g -O2 -mssse3 -msse3 -mfpmath=sse -msse -msse2 -fPIC
-I/home/dave/ros/ws_gazebo/gazebo/test/gtest/include -I/home/dave/ros/ws_gazebo/gazebo -I/home/dave/ros/ws_gazebo/gazebo/build -I/home/dave/ros/ws_gazebo/gazebo/deps -isystem /usr/include/OGRE/RTShaderSystem -isystem /usr/include/OGRE
-isystem /usr/include/OGRE/Terrain -isystem /usr/include/OGRE/Paging -isystem /usr/include/sdformat-1.4 -I/usr/include/qt4 -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtCore -fPIC -o
CMakeFiles/gazebo_gui.dir/moc_JointControlWidget.cxx.o -c /home/dave/ros/ws_gazebo/gazebo/build/gazebo/gui/moc_JointControlWidget.cxx
Originally posted by davetcoleman on Gazebo Answers with karma: 369 on 2014-01-21
Gazebo Answers logo
The current drcsim from default needs gazebo 3.0 version (current default branch). Otherwise you will get this error about SetUpperLimit.
Originally posted by Jose Luis Rivero with karma: 1485 on 2014-01-21
Comment by davetcoleman on 2014-01-21:
Ok, I'm now on default branch for Gazebo and am compiling from source. While running make I get:
/home/dave/ros/ws_gazebo/gazebo/interfaces/player/player.h:22:38: fatal error: libplayercore/playercore.h: No such file or directory I have libplayercore3.0-dev installed
Comment by Jose Luis Rivero on 2014-01-21:
You have two options: check that libplayercore/playercore.h is present in your system under /usr/include. If so, compile with VERBOSE=1 and check that there is a -I/usr/include/player3.0 as compiler parameter. In both are right, it should compile. The other option is to get rid of all the player support in gazebo (are you planning on using it?) just uninstall it: sudo apt-get remove libplayer*
sudo apt-get remove libplayer* fixed the problem, though I added more details in the question, above, and I'd be interested to know why it didn't work with it installed. Perhaps this is a bug that should be worked out in the new Gazebo 3.0?
Given your details, it could be a bug in the player support. Could you please file a bug in the gazebo bug tracker and assign it to me? Thanks for the complete report Dave.
Comment by davetcoleman on 2014-01-23:
https://bitbucket.org/osrf/gazebo/issue/1018/compiling-gazebo-30-without-player-support
