Hello,
I am very new to Ubuntu/Gazebo/ROS and am just trying to install Gazebo 1.9 (with integration to ROS Hydro on Ubuntu 14.04). I am following the directions based here: http://gazebosim.org/wiki/1.9/install I am going through the "Compiling From Source (Ubuntu)" path. I go to step 4 of "Build And Install SDFormat" and received the below error. Thanks for any help!
nbanyk@ubuntu:~/gazebo_source/sdformat/build$ cmake ../
-- The C compiler identification is GNU 4.8.2
-- The CXX compiler identification is unknown
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
CMake Error: your CXX compiler: "CMAKE_CXX_COMPILER-NOTFOUND" was not found. Please set CMAKE_CXX_COMPILER to a valid compiler path or name.
-- SDFormat version 1.4.11
-- Using upstream CFlags
====== Finding 3rd Party Packages ======
-- Operating system is Linux
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.26")
-- Could NOT find Boost
CMake Error at /usr/share/cmake-2.8/Modules/FindBoost.cmake:1131 (message):
Unable to find the requested Boost libraries.
Unable to find the Boost header files. Please set BOOST_ROOT to the root
directory containing Boost or BOOST_INCLUDEDIR to the directory containing
Boost's headers.
cmake/SearchForStuff.cmake:8 (find_package)
CMakeLists.txt:137 (include)
-- Boost not found. Please install thread signals system filesystem program_options regex boost version or higher.
-- checking for module 'tinyxml'
-- package 'tinyxml' not found
-- Looking for tinyxml headers - not found
-- Looking for tinyxml library - not found
-- Looking for tinyxml.h - not found
-- Missing: tinyxml
-- BUILD ERRORS: These must be resolved before compiling.
-- Missing: tinyxml
-- END BUILD ERRORS
CMake Error at CMakeLists.txt:175 (message):
Errors encountered in build. Please see the BUILD ERRORS above.
See also "/home/nbanyk/gazebo_source/sdformat/build/CMakeFiles/CMakeOutput.log".
See also "/home/nbanyk/gazebo_source/sdformat/build/CMakeFiles/CMakeError.log"
Originally posted by nbanyk on Gazebo Answers with karma: 104 on 2014-06-21
