I have to find the equations of motion for the given manipulator:
enter image description here
The links of the manipulator are considered weightless and the equations of motion have to be derived by using the Lagrange equations. The coordinated of the point mass are:
$$ x_m = q_1+l_1+l_2c_2 $$ $$ y_m = l_2s_2 $$ And the Lagrangian of the system is:
$$ L = T - V = \frac{1}{2}\cdot \Big[\dot{q_1}^2-2l_2s_2\dot{q_1}\dot{q_2}+l_2^2\dot{q_2}^2\Big]-mgl_2s_2 $$
Now, in order to find the equations of motion, I applied the Lagrange's Method:
$$ \frac{d}{dt}\Big(\frac{\partial L}{\partial \dot{q_i}}\Big) - \frac{\partial L}{\partial q_i} = \tau_i $$
And the final equations of motion written in matrix form are:
$$ \begin{bmatrix} m & -ml_2s_2 \\ -ml_2s_2 & ml_2^2 \end{bmatrix}\cdot \begin{bmatrix} \ddot{q_1} \\ \ddot{q_2} \end{bmatrix} + \begin{bmatrix} 0 & -ml_2c_2\dot{q_2} \\ 0 & 0 \end{bmatrix}\cdot \begin{bmatrix} \dot{q_1} \\ \dot{q_2} \end{bmatrix} + \begin{bmatrix} 0 \\ mgl_2c_2 \end{bmatrix}=\begin{bmatrix} \tau_1 \\ \tau_2 \end{bmatrix} $$
The above equations of motion have been derived by ignoring the force applied $F_x$. Now, my issue is how to include this force in terms of the Lagrange Method. Should I modify the method like the one below:
$$ \frac{d}{dt}\Big(\frac{\partial L}{\partial \dot{q_i}}\Big) - \frac{\partial L}{\partial q_i} = \tau_i + F_x $$
But in which of the two equations of motion should the force be included ? The force $F_x$ is an external constant force applied in the direction of $x_0$.
In Lagrangian mechanics, you're required to deal with the generalized forces and the concept of virtual work $\delta W$.
In our case we have: $$ \delta W_{F_x} = F_x \cdot \delta q_1 + F_x \left( -l_2s_2\right) \cdot \delta q_2, $$
where the coefficients of the terms $\delta q_i$ are given by $F_x \frac{\partial x_m}{\partial q_i}$. By contrast, $y_m$ doesn't provide any contribution to the virtual work as $F_y = 0$.
This sums up in the final equation as: $$ ...=\begin{bmatrix} \tau_1 + F_x \\ \tau_2 -F_xl_2s_2 \end{bmatrix}. $$
In particular, $\tau_1$ is a force actuating the prismatic joint $q_1$, whereas $\tau_2$ is a torque actuating the revolute joint $q_2$. Therefore, units are consistent.
