I followed the instruction as mentioned here. Everything worked fine but at last stage when I try to run:-
roslaunch px4 multi_uav_mavros_sitl.launch
I get following:-
... logging to /home/yograj/.ros/log/40d4394e-0a3d-11e8-a1f1-3c77e68de09b/roslaunch-yograj-Inspiron-5537-12334.log
Press Ctrl-C to interrupt
Usage: xacro.py [options] <input>
xacro.py: error: expected exactly one input file as argument
while processing /home/yograj/src/Firmware/launch/single_vehcile_spawn.launch:
Invalid <param> tag: Cannot load command parameter [iris_1_sdf]: command [/opt/ros/kinetic/share/xacro/xacro.py /home/yograj/src/Firmware/Tools/sitl_gazebo/models/rotors_description/urdf/iris_base.xacro rotors_description_dir:=/home/yograj/src/Firmware/Tools/sitl_gazebo/models/rotors_description mavlink_udp_port:=14560 > iris_1.urdf ; 'gz sdf -p iris_1.urdf'] returned with code [2].
Param xml is <param command="$(arg cmd)" name="$(arg vehicle)_$(arg ID)_sdf"/>
The traceback for the exception was written to the log file
Launch file
<launch>
    <!-- Posix SITL environment launch script -->
    <arg name="x" default="0"/>
    <arg name="y" default="0"/>
    <arg name="z" default="0"/>
    <arg name="R" default="0"/>
    <arg name="P" default="0"/>
    <arg name="Y" default="0"/>
    <arg name="est" default="ekf2"/>
    <arg name="vehicle" default="iris"/>
    <arg name="ID" default="1"/>
    <arg name="rcS" default="$(find px4)/posix-configs/SITL/init/$(arg est)/$(arg vehicle)_$(arg ID)"/>
    <arg name="mavlink_udp_port" default="14560" />
    <arg name="cmd" default="$(find xacro)/xacro.py $(find px4)/Tools/sitl_gazebo/models/rotors_description/urdf/$(arg vehicle)_base.xacro rotors_description_dir:=$(find px4)/Tools/sitl_gazebo/models/rotors_description mavlink_udp_port:=$(arg mavlink_udp_port) > $(arg vehicle)_$(arg ID).urdf ; 'gz sdf -p $(arg vehicle)_$(arg ID).urdf'" />
    <param command="$(arg cmd)" name="$(arg vehicle)_$(arg ID)_sdf" />
    <node name="sitl_$(arg ID)" pkg="px4" type="px4" output="screen"
        args="$(find px4) $(arg rcS)">
    </node>
    <node name="$(arg vehicle)_$(arg ID)_spawn" output="screen" pkg="gazebo_ros" type="spawn_model"
        args="-sdf -param $(arg vehicle)_$(arg ID)_sdf -model $(arg vehicle)_$(arg ID) -x $(arg x) -y $(arg y) -z $(arg z) -R $(arg R) -P $(arg P) -Y $(arg Y)" respawn="false"/>
</launch>
<!-- vim: set et ft=xml fenc=utf-8 ff=unix sts=0 sw=4 ts=4 : -->
  • $\begingroup$ Your launch file seems incorrect. Either that or you don't have the urdf file you are trying to load. As said in the error log, xacro needs on input file but did not get it. Can you post your launch file ? $\endgroup$
    – Malcolm
    Feb 5, 2018 at 12:38
If you are using old version of px4 firmware. There was some problem with launch file (single_vehcile_spawn.launch). Correcting
in single_vehcile_spawn.launch with
<arg name="cmd" default="$(find xacro)/xacro.py $(find px4)/Tools/sitl_gazebo/models/rotors_description/urdf/$(arg vehicle)_base.xacro rotors_description_dir:=$(find px4)/Tools/sitl_gazebo/models/rotors_description mavlink_udp_port:=$(arg mavlink_udp_port)" />
