Using Ubuntu 14.04 with ROS Indigo installed. Trying to implement Moveit example for baxter.
I updated the baxter to the new sdk. Version 1.2.
Runnig
roslaunch baxter_moveit_config baxter_grippers.launch
gives me this error
... logging to /home/colab/.ros/log/3c0648a4-bdfe-11e5-aedd-000af70eb5a9/roslaunch-ros-monster-10040.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
while processing /home/colab/ros/ws_baxter_sdk/src/moveit_robots/baxter/baxter_moveit_config/launch/planning_context.launch: Invalid tag: Cannot load command parameter [robot_description_semantic]: command [/opt/ros/indigo/share/xacro/xacro.py --inorder /home/colab/ros/ws_baxter_sdk/src/moveit_robots/baxter/baxter_moveit_config/config/baxter.srdf.xacro left_electric_gripper:=true right_electric_gripper:=true left_tip_name:=left_gripper right_tip_name:=right_gripper] returned with code [2].
Param xml is The traceback for the exception was written to the log file
Cannot understand the error. Please assist. Thank you
Originally posted by rdhn on ROS Answers with karma: 51 on 2016-01-18
It sounds like your Debain ROS installation is in a broken state. I believe roslaunch is telling you that xacro failed to create the SDF file. This is likely due to using an old version of xacro. I recommend updating your install:
$ sudo apt-get install --only-upgrade ros-indigo-xacro
If that doesn't work, you may need to update your entire set of ROS packages. The best way I know of for this (please correct me if I am wrong here):
$ sudo apt-get dist-upgrade
That will upgrade all of your out of date packages (ROS and otherwise), and remove any old and conflicting packages.
Originally posted by imcmahon with karma: 790 on 2016-01-18
Comment by rdhn on 2016-01-19:
Still no luck. The roslaunch command still gets stuck.
