In my program, I'm need to detect if the NXT touch sensor is pressed.
var nxt = new Brick<Sensor, Sensor, Sensor, Sensor>("usb");
nxt.Connection.Open();
nxt.Sensor1 = new TouchSensor();
nxt.Sensor1.Reset(false);
nxt.Sensor1.Initialize();
Console.WriteLine(nxt.Sensor1);
When I start the program, the sensor value always reads 0. But I discovered that if I go into the "View" menu in the NXT and see the touch sensor value, the program value reads 1. I can't do that for my setup. Also, I can't use Bluetooth; my computer doesn't have it. Can someone help me?
EDIT: my full code
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using MonoBrick.NXT;
using MonoBrick;
using System.Windows.Forms;
using System.Reflection;
using System.Threading;
namespace MonoBrick
class Program
[STAThread]
static void Main(string[] args)
try
Console.WriteLine(nxt.Sensor1.ReadAsString());
nxt.Beep(500);
System.Windows.Application application = new System.Windows.Application();
application.Run(new Window1());
nxt.Connection.Close();
catch (Exception e)
Console.WriteLine("Error: " + e.Message);
Console.WriteLine("Press any key to end...");
Console.ReadKey();
