I want to use Nav2 for robot navigation. The robot that I am using is a skid-steer-tracked robot that does not provide reliable odometry data. I am trying to use the robot_localization package to get the odometry from the imu and then use it as an input to nav2 using a laser scanner. I am not getting any messages published on the odometry/filtered topic of the robot_localization package but I get the following message on the /diagnostics topic. Could someone please guide me on this issue?
header:
stamp:
sec: 1723455685
nanosec: 294059951
frame_id: ''
status:
- level: "\x02"
name: 'ekf_filter_node: Filter diagnostic updater'
message: Erroneous data or settings detected for a robot_localization state estimation this->
hardware_id: none
values:
- key: X_configuration
value: Neither X nor its velocity is being measured. This will result in unboundederror growth and erratic filter behavior.
- key: Y_configuration
value: Neither Y nor its velocity is being measured. This will result in unboundederror growth and erratic filter behavior.
- key: Z_configuration
value: Neither Z nor its velocity is being measured. This will result in unboundederror growth and erratic filter behavior.
- level: "\x02"
name: 'ekf_filter_node: odometry/filtered topic status'
message: No events recorded.
hardware_id: none
values:
- key: Events in window
value: '0'
- key: Events since startup
value: '0'
- key: Duration of window (s)
value: '5.066757'
- key: Actual frequency (Hz)
value: '0.000000'
- key: Minimum acceptable frequency (Hz)
value: '25.200000'
- key: Maximum acceptable frequency (Hz)
value: '35.200000'
Here is my ekf params file for reference:
### ekf config file ###
ekf_filter_node:
ros__parameters:
frequency: 30.0
sensor_timeout: 0.1
two_d_mode: true
transform_time_offset: 0.0
transform_timeout: 0.0
print_diagnostics: true
debug: false
debug_out_file: /path/to/debug/file.txt
permit_corrected_publication: false
publish_acceleration: false
publish_tf: true
map_frame: map # Defaults to "map" if unspecified
odom_frame: odom # Defaults to "odom" if unspecified
base_link_frame: base_link # Defaults to "base_link" if unspecified
world_frame: odom # Defaults to the value of odom_frame if unspecified
imu0: imu/data
imu0_config: [false, false, false,
true, true, true,
true, true, true,
true, true, true]
imu0_differential: false
imu0_relative: true
imu0_queue_size: 5
imu0_pose_rejection_threshold: 0.8 #
imu0_twist_rejection_threshold: 0.8 #
imu0_linear_acceleration_rejection_threshold: 0.8 #
imu0_remove_gravitational_acceleration: true
use_control: false
process_noise_covariance: [0.05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.06, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.03, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.03, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.06, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.025, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.025, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.04, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.02, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.015]
initial_estimate_covariance: [1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9, 1e-9]
