I using Ububtu 14.04 and ros-indigo-devel for robot_localization
This my ukf.yaml
frequency: 30 sensor_timeout: 0.1 transform_time_offset: 0.0 two_d_mode: true print_diagnostics: true map_frame: map odom_frame: odom base_link_frame: base_link world_frame: odom alpha: 0.001 kappa: 0 beta: 2 odom0: /odom odom0_config: [false,false,false, false, false, false, true, false, false, false, false, false, false, false, false] odom0_differential: false odom0_relative: false odom0_queue_size: 50 odom0_nodelay: false
I confirm the position.z is zero in /odom messages.
I start 2d pose estimate using ukf and pose_z is non-zero value.
I try track it and find out when computing sigma point , the position.z provide non-zero value.
sigmaPoints_[sigmaInd + 1] = transferFunction_ * (state_ + weightedCovarSqrt_.col(sigmaInd));
in ukf.cpp
Is it OK ?
By the way , I using EKF to estimate pose and position.z is always zero.
Sample input is from odom
image description http://blackdragonyu.no-ip.org/web_images/2016-10-24_181611.png
The attachments are my UKF and EKF yaml
http://gofile.me/2jhbn/ZEJnxxcKD
The output please see these images:
image description http://blackdragonyu.no-ip.org/web_images/2016-10-24_191341.png
image description http://blackdragonyu.no-ip.org/web_images/2016-10-24_191433.png
Update 1 :
The following is my log. Please reference
When starting UKF localization , I found create sigma points that just provide non-zero for z-position of robot's pose image description http://blackdragonyu.no-ip.org/web_images/ukf2.png
Because all sigma point are not zero , the z-position of robot's pose is not zero also. image description http://blackdragonyu.no-ip.org/web_images/ukf.png
Originally posted by sai5555 on ROS Answers with karma: 1 on 2016-10-19
Comment by Tom Moore on 2016-10-24:
Can you please clean up the .yaml printout and also post sample inputs from every message? Thank you.
Also, have you tried using the EKF to see if it behaves the same way?
Comment by sai5555 on 2016-10-24:
Yes , I tried EKF using same yaml and EKF dont have this problem
Comment by Tom Moore on 2016-11-01:
1e-18
is effectively 0. Does it ever become larger, or does it stay around there?
Comment by sai5555 on 2016-11-07:
About le-18~le-20
