I have a "Node" class, used for pathfinding. However, when I try to use it anywhere in my rclcpp project, I get errors like "error: cannot convert ‘rclcpp::Node*’ to ‘Node*’". I would expect this if I had specified "using namespace rclcpp" somewhere, but I didn't do that. Why would rclcpp::Node be conflicting with my global namespace Node class? What would be the best way to resolve this? I would like to avoid renaming my "Node" class, as it shouldn't be necessary if rclcpp is behaving properly.
Thanks!
  • $\begingroup$ Can you post a minimal code example that shows the behavior? $\endgroup$
    – JRTG
    Commented Apr 22 at 2:01
  • $\begingroup$ @JRTG I don't think this requires a code example since his problem is directly from docs. The class extends rclcpp::Node, but delegates construction to Node. This works and also surprised me. I don't think this is really desirable because there are plenty of use cases to call something Node and provocate a conflict. But I also don't think there is a direct answer to the question. He can't do much about it except namespace himself. $\endgroup$
    – Nyquist
    Commented Apr 24 at 17:51
  • $\begingroup$ @Nyquist The problem is not "directly from the docs", as the example you refer to compiles and runs just fine, without any issues. However, based on your comment I guess that what the OP means is that he implemented class Node : public rclcpp::Node{ ... }, which obviously seems bound for trouble. Then again, I re-read the question, and it could as well be that it's about a Node class and a rclcpp::Node class that are completely unrelated. Anyway, I have no intention to spend any more time on this question as long as I have to guess about the exact issue the OP wants to address. $\endgroup$
    – JRTG
    Commented Apr 25 at 7:27
  • $\begingroup$ I haven't thought about the former situation, but mainly refered to the latter. As I said, it is what I encountered myself. Using a library that uses a Node class that I use in the same scope as the rclcpp::Node, which is rather annoying. Anyhow, you are right, for the sake of focus of this question OP should clarify. $\endgroup$
    – Nyquist
    Commented Apr 25 at 7:33
