I tried to create a navigation algorithm using nav2 and GPS data for the global odometry. With the help of the robot_localization package, I successfully created global odometry data by fusing the data from the wheel encoder, IMU, and GPS. When I am trying to add a navigation algorithm for waypoint navigation, nothing is published on the /map topic, and no costmap is generated. No node publishes anything on the /map topic, so I can't run the navigation algorithm:
This is my launch file:
import os
from ament_index_python.packages import get_package_share_directory
from launch.substitutions import LaunchConfiguration, Command
from launch.actions import IncludeLaunchDescription, DeclareLaunchArgument
from launch.launch_description_sources import PythonLaunchDescriptionSource
from launch.conditions import IfCondition
from nav2_common.launch import RewrittenYaml
from launch_ros.actions import Node
from launch_ros.substitutions import FindPackageShare
# Get the launch directory
bringup_dir = get_package_share_directory('nav2_bringup')
gps_wpf_dir = get_package_share_directory("nav2_gps_waypoint_follower_demo")
launch_dir = os.path.join(gps_wpf_dir, 'launch')
params_dir = os.path.join(gps_wpf_dir, "config")
nav2_params = os.path.join(params_dir, "nav2_no_map_params.yaml")
configured_params = RewrittenYaml(
source_file=nav2_params, root_key="", param_rewrites="", convert_types=True
pkg_share = get_package_share_directory('nav2_gps_waypoint_follower_demo')
pkg_gazebo_ros = get_package_share_directory('gazebo_ros')
path_lafette = os.path.join(pkg_share, 'urdf', 'Lafette_small_urdf.urdf')
use_rviz = LaunchConfiguration('use_rviz')
declare_use_rviz_cmd = DeclareLaunchArgument(
'use_rviz',
default_value='True',
description='Whether to start RVIZ')
launch_gazebo_cmd = IncludeLaunchDescription(
PythonLaunchDescriptionSource(os.path.join(pkg_share, 'launch', 'launch_lafette_gazebo.launch.py'))
robot_localization_cmd = IncludeLaunchDescription(
os.path.join(launch_dir, 'dual_ekf_navsat.launch.py'))
navigation2_cmd = IncludeLaunchDescription(
PythonLaunchDescriptionSource(os.path.join(bringup_dir, "launch", "navigation_launch.py")),
launch_arguments={
"use_sim_time": "True",
"params_file": configured_params,
"autostart": "True",
}.items(),
rviz_cmd = IncludeLaunchDescription(
os.path.join(bringup_dir, "launch", 'rviz_launch.py')),
condition=IfCondition(use_rviz)
# Create the launch description and populate
ld = LaunchDescription()
# rviz launch
ld.add_action(declare_use_rviz_cmd)
ld.add_action(rviz_cmd)
#interfaces
ld.add_action(launch_gazebo_cmd)
# robot localization launch
ld.add_action(robot_localization_cmd)
# navigation2 launch
ld.add_action(navigation2_cmd)
return ld
dual_ekf_navsat.launch.py looks like:
import launch_ros.actions
import os
import launch.actions
rl_params_file = os.path.join(gps_wpf_dir, "config", "dual_ekf_navsat_params.yaml")
return LaunchDescription(
launch.actions.DeclareLaunchArgument(
"output_final_position", default_value="false"
"output_location", default_value="~/dual_ekf_navsat_example_debug.txt"
launch_ros.actions.Node(
package="robot_localization",
executable="ekf_node",
name="ekf_filter_node_odom",
output="screen",
parameters=[rl_params_file, {"use_sim_time": True}],
remappings=[("odometry/filtered", "odometry/local")],
name="ekf_filter_node_map",
output="screen",
remappings=[("odometry/filtered", "odometry/global")],
executable="navsat_transform_node",
name="navsat_transform",
output="screen",
remappings=[
("imu/data", "imu/data"),
("gps/fix", "gps/fix"),
("gps/filtered", "gps/filtered"),
("odometry/gps", "odometry/gps"),
("odometry/filtered", "odometry/global"),
The configuration file for the EKF in "dual_ekf_navsat_params.yaml" looks like
# Sensor fusion for the odom frame
ekf_filter_node_odom:
ros__parameters:
frequency: 30.0
two_d_mode: true # Recommended to use 2d mode for nav2 in mostly planar environments
print_diagnostics: true
debug: false
publish_tf: true
map_frame: map
odom_frame: odom
base_link_frame: base_footprint # the frame id used by the turtlebot's diff drive plugin
world_frame: odom # the frame to be fused
odom0: odom
odom0_config: [false, false, false,
true, true, true,
false, false, true,
false, false, false]
odom0_queue_size: 10
odom0_differential: false
odom0_relative: false
imu0: imu
imu0_config: [false, false, false,
false, false, true,
imu0_differential: false # If using a real robot you might want to set this to true, since usually absolute measurements from real imu's are not very accurate
imu0_relative: false
imu0_queue_size: 10
imu0_remove_gravitational_acceleration: true
use_control: false
process_noise_covariance: [1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.1, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3]
# Sensor fusion for the map frame
ekf_filter_node_map:
ros__parameters:
frequency: 30.0
debug: false
publish_tf: true
map_frame: map
odom_frame: odom
world_frame: map # the frame to be fused
odom0: odom
true, true, true,
false, false, true,
odom1: odometry/gps
odom1_config: [true, true, false,
odom1_queue_size: 10
odom1_differential: false
odom1_relative: false
imu0: imu
false, false, true,
imu0_queue_size: 10
use_control: false
process_noise_covariance: [1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
navsat_transform:
ros__parameters:
frequency: 30.0
delay: 3.0
magnetic_declination_radians: 0.0
yaw_offset: 0.0
zero_altitude: true
broadcast_utm_transform: true
publish_filtered_gps: true
use_odometry_yaw: true
wait_for_datum: false
If you could guide me on what might help get the /map topic published, I would be grateful.
I use ros2 humble.
