I want to implement the J+RRT algorithm for which I need to use the Twist command to navigate the robot in Euclidean space.
First I calculate the difference in rotation matrices from the end-effector frame T1
to the goal frame T2
like so:
Tdiff * T1 = T2 // * T1^-1
Tdiff * T1 * T1^-1 = T2 * T1^-1
Tdiff = T2 * T1^-1
I am using the Frame separated as a rotation and translation. Effectively this means that
T1^-1 = [R1^T -t1; 0 0 0 1]
RPY seems to be given in extrinsic x, y, z angles, which means that I need to convert it to intrinsic angles for the Twist command. This means that the RPY angles that I get from the Tdiff
I would need to convert to my R1
rotation frame. Is my thinking correct?
The code I'm using is this:
KDL::Rotation inv_src_rot = src.M.Inverse();
double x, y, z;
KDL::Rotation diff_rot = tgt.M * inv_src_rot;
diff_rot.GetRPY(x, y, z);
twist.rot = src.M * KDL::Vector(x, y, z);
This is the code for the RPY calculation: https://github.com/orocos/orocos_kinematics_dynamics/blob/master/orocos_kdl/src/frames.cpp#L237-L260
EDIT: Right as I posted this I had another idea, which seems to me more correct.
If my goal is to go towards the goal rotation tgt.M
in the end-effector reference frame src.M
, it would make sense to calculate the RPY angles from the rotation
src.M * tgt.M
since in this case the extrinsic frame has now become src.M
. Now when I calculate RPY it will be the rotation tgt.M
given in the src.M
frame, if I'm not mistaken?
KDL::Rotation diff_rot = src.M * tgt.M;
twist.rot = KDL::Vector(x, y, z);
