I am trying to publish a ROS message in Python but I do not know the message type. I tried using AnyMsg and it did not work. If this is possible would someone be able to provide a Python code snippet?
1 Answer
You can use AnyMsg
to subscribe to the topic, then use this to acquire information about the topic which can be used to construct a publisher and a new message which can be published. For an example, see below.
import rospy
import genpy
from rospy.msg import AnyMsg
rospy.init_node("test_node")
publisher = None
msg_class = None
# callback that we'll use to setup the publisher once we've gotten a message
def setup_publisher(msg):
global msg_class
global publisher
topic_type = msg._connection_header["type"]
msg_class = genpy.message.get_message_class(topic_type)
publisher = rospy.Publisher("test_topic", msg_class, queue_size=10)
# subscribe and wait for a message to come in
check_rate = rospy.Rate(10)
sub = rospy.Subscriber("test_topic", AnyMsg, setup_publisher)
while publisher is None and not rospy.is_shutdown():
check_rate.sleep()
sub.unregister() # all done with the subscriber now
assert publisher is not None
# now that we have a valid publisher we can create a new message.
# we could use genpy like in the callback, or we can just use the
# publisher:
new_msg = publisher.data_class()
# even if we don't know what type it is beforehand,
# we can find out what information can be populated
# thanks to the 'slots' attribute provided by messages
if "data" in new_msg.__slots__:
if type(new_msg.data) == int:
new_msg.data = 42
elif type(new_msg.data) == str:
new_msg.data = "Hello World!"
elif type(new_msg.data) == float:
new_msg.data = 3.14159
# we can also make use of the setattr/gettattr
# functions in a slightly more traditionally-python way
for slot in dir(new_msg):
if slot.startswith("_"):
# ignore private attributes
continue
if type(getattr(new_msg, slot)) == int:
# set any integer to 42
setattr(new_msg, slot, 42)
# now we can publish the message
publisher.publish(new_msg)
But, notice that we need to do some introspection on the message to find/set fields if we don't know them beforehand, and this can be a bit messy. For that reason, whenever you can, it's recommended to just use the message.
