Hi all, I am using ROS Noetic. I tried to publish one message without "while infinite loop" in the node that I created. In fact, I need just to publish one message from the topic to socketCAN but it doesn't work. I know that the node will be killed but it should publish one message?!! Anybody know why ? Thank you.
Originally posted by mros on ROS Answers with karma: 23 on 2020-12-10
Comment by Akhil Kurup on 2020-12-10:
We don't know what your code looks like and what message you are trying to publish and where. Please post your code, at least a snippet, so we can get context. Also, please be more detailed in your question. What have you tried so far and what errors you are facing (if any)!
It most likely is the case that your publisher is publishing your message before any subscribers to that message have been connected. It takes a "non-zero" amount of time for the "hand-shaking" to occur through the ROS master and between the publisher/subscriber nodes. You can write a section of code that will wait for a subscriber, publish the message (to that subscriber) then shut down the node. If you immediately shutdown a node after calling publish on a publisher it is not guaranteed that the message was sent and received by the subscriber.
A convenient overload to the advertise function provided by the NodeHandle class allows a client to specify a SubscriberStatusCallback function pointer that gets called when a new subscriber connects to the publisher see the rosdocs.
Here is a simple code example with a std_msgs/String topic:
#include <std_msgs/String.h>
#include <ros/ros.h>
void subscriberConnectCallback(const ros::SingleSubscriberPublisher& publisher)
  ROS_INFO("Super cool I got a new subscriber [%s] on the %s topic!", publisher.getSubscriberName().c_str(),
           publisher.getTopic().c_str());
  // Build the message and publish
  std_msgs::String msg;
  msg.data = "super cool";
  publisher.publish(msg);
  // Signal shutdown
  ros::shutdown();
int main(int argc, char* argv[])
  ros::init(argc, argv, "test_node");
  // Create publisher with private node handle and bind callback to handle subscriber connection
  ros::NodeHandle pnh("~");
  ros::Publisher publisher =
      pnh.advertise<std_msgs::String>("chatter", 1, (ros::SubscriberStatusCallback)subscriberConnectCallback);
  // Spin this node until a shutdown is triggered
  ros::spin();
  return 0;
Originally posted by danambrosio with karma: 106 on 2020-12-10
Comment by mros on 2020-12-11:
Hello, Thank you so much for your help, it works well but I had to remove ("~").
Comment by jarvisschultz on 2020-12-11:
@mros If this is the correct answer and it solved your issue, please mark this answer as correct.
Comment by danambrosio on 2020-12-11:
Just for your information, the private node handle is commonly used for publishers and would require a rosrun argument remap or launch remap.
The ability to remap topics/services/actions is useful to prevent hardcoded topics/service names in a node.
