I am trying to be able to control when do I publish so I tried to put the rospy.Timer in a while loop. I did not use rospy.Rate or rate.sleep because I found out that it somehow interferes with the signal of another node(if someone could help on this would be nice too). However when I put the rospy.Timer in a loop it does not seem working as intended
This is my publisher code
   #!/usr/bin/env python
     import rospy
     from std_msgs.msg import Int16
     pub_1=rospy.Publisher('file_update',Int16,queue_size=30)
     shutdown_signal = False  # Flag to indicate whether to shut down the publisher
     rate=10
     def update_file():
     global shutdown_signal
     while not shutdown_signal:
         rospy.Timer(rospy.Duration(1/rate),publish)
  def publish(event):
     num_msg=23
     pub_1.publish(num_msg)
  def shutdown(data):
     shutdown_signal = True
     #rospy.loginfo("Received shutdown signal")
 if __name__ == '__main__':
    rospy.init_node('file_update_publisher', anonymous=True)
    rospy.Subscriber('shutdown_publisher', String, shutdown)
    try:
        update_file()
    except rospy.ROSInterruptException:
        print("An exception occured")
And this is my subscriber code
  #!/usr/bin/env python3
  import rospy
  def file_update_callback(data):
      number=data.data
      print(number)
      shutdown_pub = rospy.Publisher('shutdown_publisher', String, queue_size=1)
      shutdown_pub.publish("Shutdown")
  def listen_file_update():
      rospy.init_node('file_update_listener', anonymous=True)
      rospy.Subscriber('file_update', Int16, file_update_callback)
      rospy.spin()
The rospy.Timer object is designed to operate asynchronously. When you create a Timer inside a while loop, it attempts to create a new timer on each iteration of the loop. This will lead to unexpected behavior, as these timers are not being properly managed or canceled.
The callback publish in the Timer is designed to be called at regular intervals specified by the duration.
Revised publisher code (with minimal changes):
import rospy
from std_msgs.msg import Int16, String
pub_1 = rospy.Publisher('file_update', Int16, queue_size=30)
def publish(event):
    if not shutdown_signal:
        num_msg = 23
def shutdown(data):
    rate = 10
    timer = rospy.Timer(rospy.Duration(1/rate), publish)
    rospy.spin()
    timer.shutdown()
Feel free to build on this code, specifically the update_file function. If you are starting ROS development, I would recommend switching to ROS 2.
