How to fix it:
#### Running command: "make cmake_check_build_system" in "/home/user/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/user/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/melodic
-- This workspace overlays: /opt/ros/melodic
-- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.17", minimum required is "2")
-- Using PYTHON_EXECUTABLE: /usr/bin/python2
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR:
 /home/user/catkin_ws/build/test_results
-- Found gtest sources under '/usr/src/googletest': gtests will be built
-- Found gmock sources under '/usr/src/googletest': gmock will be built
-- Found PythonInterp: /usr/bin/python2 (found version "2.7.17")
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.7.29
-- BUILD_SHARED_LIBS is on
-- ~~  traversing 1 packages in topological order:
-- ~~  - dope
-- +++ processing catkin package: 'dope'
-- ==> add_subdirectory(dope)
-- Could NOT find resource_retriever (missing: resource_retriever_DIR)
-- Could not find the required component 'resource_retriever'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/melodic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
  Could not find a package configuration file provided by
  "resource_retriever" with any of the following names:
    resource_retrieverConfig.cmake
    resource_retriever-config.cmake
  Add the installation prefix of "resource_retriever" to CMAKE_PREFIX_PATH or
  set "resource_retriever_DIR" to a directory containing one of the above
  files.  If "resource_retriever" provides a separate development package or
  SDK, be sure it has been installed.
  dope/CMakeLists.txt:10 (find_package)
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/user/catkin_ws/build/CMakeFiles/CMakeError.log".
Makefile:1118: recipe for target 'cmake_check_build_system' failed
make: *** [cmake_check_build_system] Error 1
  • $\begingroup$ You have not provided enough information for us to help. Please edit your question and provide a url to the source code for this ros package. $\endgroup$
    – Mike973
    Commented Nov 22, 2023 at 17:15
  • $\begingroup$ Please try installing resource_retriever using sudo apt install ros-melodic-resource-retriever $\endgroup$
    – ravi
    Commented Nov 23, 2023 at 3:28
