When building ROS2 Humble from source there are over 300 packages that need to be built when you follow the official instructions.
Are all of these packages required to run ROS2 Humble? Can I cut this list down and still run ros2 humble?
Thank you
Take a look at the package requirements for the core and base variants at
https://www.ros.org/reps/rep-2001.html
There's some context and discussion here
https://github.com/ros2/ros2_documentation/issues/870
and here
https://discourse.ros.org/t/core-base-and-desktop-releases/20267/2
that might help you set up a minimal source install.
