I've been encountering an issue while attempting to install ROS 2 Humble on my Ubuntu 20.04 system. My machine supports both arm64 and x86_64 architectures. Despite following the official installation instructions closely, I run into the "unable to locate package ros-humble-desktop" error every time I try to execute the installation command.
Here are the steps I've followed based on the instructions from the ROS.org page for Humble:
1. Added the ROS 2 repository and keyring as follows:
sudo apt update && sudo apt install curl -y
sudo curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] http://packages.ros.org/ros2/ubuntu $(. /etc/os-release && echo $UBUNTU_CODENAME) main" | sudo tee /etc/apt/sources.list.d/ros2.list > /dev/null
2. Updated and upgraded my package lists:
   sudo apt update
   sudo apt upgrade
3. Attempted to install ROS 2 Humble packages:
   sudo apt install ros-humble-desktop
However, this results in the "unable to locate package ros-humble-desktop" error.
Interestingly, I came across a similar issue on ROS Answers where a user encountered package location errors due to their system running on an ARMhf platform. However, after checking my system using dpkg --print-architecture and lscpu, I confirmed that my system is on arm64 and x86_64, which should be compatible with ROS 2 Humble according to REP 2000.
I'm reaching out to see if anyone has faced a similar issue or could offer guidance on resolving this error. Could this problem be related to my prior attempts to uninstall ROS 2 Foxy and clean my system? Or is there something else I'm missing in the setup process for ROS 2 Humble on Ubuntu 20.04?
Any advice or suggestions would be greatly appreciated. Thank you in advance for your help!
In normal case, ROS2 Humble binary installation is available in Ubuntu 22.04 version, unless you have built a separate container environment.
enter image description here
**Installation**
Options for installing ROS 2 Humble Hawksbill:
Binary packages
Binaries are only created for the Tier 1 operating systems listed in REP-2000. Given the nature of Rolling, this list may be updated at any time. If you are not running any of the following operating systems you may need to build from source or use a container solution to run ROS 2 on your platform.
We provide ROS 2 binary packages for the following platforms:
Ubuntu Linux - Jammy Jellyfish (22.04)
Debian packages (recommended)
“fat” archive
RHEL 8
RPM packages (recommended)
“fat” archive
Windows (VS 2019)
Or you could try Source Install https://docs.ros.org/en/humble/Installation/Alternatives/Ubuntu-Development-Setup.html enter image description here
Ubuntu (source)
Table of Contents
System requirements
System setup
Set locale
Add the ROS 2 apt repository
Install development tools and ROS tools
Get ROS 2 code
Install dependencies using rosdep
Install additional DDS implementations (optional)
Build the code in the workspace
Environment setup
Source the setup script
Try some examples
Next steps after installing
Using the ROS 1 bridge
Additional RMW implementations (optional)
Alternate compilers
Clang
Stay up to date
Troubleshooting
Uninstall
System requirements
The current Debian-based target platforms for Humble Hawksbill are:
Tier 1: Ubuntu Linux - Jammy (22.04) 64-bit
Tier 3: Ubuntu Linux - Focal (20.04) 64-bit
Tier 3: Debian Linux - Bullseye (11) 64-bit
5
  • $\begingroup$ I do, however, use Ubuntu 20.04. In any case, as stated in the documents, Ubuntu 20.04 is also supported. But the issue persists, and it truly puzzles me. $\endgroup$
    – Shadowolf
    Feb 14 at 11:58
  • $\begingroup$ I don't know exactly what your intentions are, but I recommend you try the source install. docs.ros.org/en/humble/Installation/Alternatives/… $\endgroup$ Feb 14 at 12:25
  • $\begingroup$ Please copy and paste the text and not a screenshot. Images are not text searchable. $\endgroup$ Feb 14 at 13:11
  • $\begingroup$ Thanks, added the text. $\endgroup$ Feb 14 at 15:41
  • $\begingroup$ Thank you for your help, I decided to continue with Ubuntu 22.04, it works seamlessly with it. $\endgroup$
    – Shadowolf
    Feb 14 at 16:27
