I'm trying to convert tf2::Transform
to geometry_msgs::msg::Transform
with help of tf2/convert.h
but I get compiler errors. I'm using ROS2 Humble with Ubuntu 22.04.
What I'm doing wrong?
tf2::Transform transform;
// make something with transform ...
// Build a TransformStamped message
geometry_msgs::msg::TransformStamped t;
t.header.stamp = node->get_clock()->now();
t.header.frame_id = frame_id;
t.child_frame_id = child_frame_id;
// Now try to assign the tf2::Transform to the transform in the message
t.transform = tf2::toMsg<tf2::Transform, geometry_msgs::msg::Transform>(transform);
Error undefined reference to geometry_msgs::msg::Transform_std::allocator<void > tf2::toMsg<tf2::Transform, geometry_msgs::msg::Transform_std::allocator<void > >(tf2::Transform const&)'
// Another try with another function, this fails too
tf2::convert(transform, t.transform)
Error /opt/ros/humble/include/tf2/tf2/impl/convert.h:67:12: error: no matching function for call to ‘toMsg(const tf2::Transform&)’ 67 | b = toMsg(a);
