I am writing a custom costmap layer to read data from a radar sensor and turn it into a costmap, and I'm facing some issues running it. I get the following error when it runs:
symbol lookup error: /home/mkhoory/sdc/catkin_ws/devel/lib//libRadarDataLayer.so: undefined symbol: _ZN3tf212getTimestampIN13geometry_msgs15PolygonStamped_ISaIvEEEEERKN3ros4TimeERKT_
What the related code is trying to do is create a PolygonStamped from the radar data and convert it to world coordinates via tf2.
tfBuffer.transform(polyRadar, polyWorld, globalFrame);
I'm not sure what I'm doing wrong here. The code compiles fine, and it's only when the plugin reaches the above line that it tells me that it's an undefined reference. I tried including tf2_geometry_msgs.h but that didn't do anything. What am I missing?
EDIT: Here's my CMakeLists.txt:
project(my_project_processing)
  roscpp
  rospy
  std_msgs
  geometry_msgs
  message_generation
  tf
  tf2
  tf2_geometry_msgs
  costmap_2d
  dynamic_reconfigure
  my_project_sensors
find_package(Boost REQUIRED COMPONENTS system thread)
add_message_files(
    FILES
    CommandMessage.msg
generate_messages(
  DEPENDENCIES
  std_msgs
  geometry_msgs
catkin_package(
  INCLUDE_DIRS include
  LIBRARIES
  CATKIN_DEPENDS roscpp rospy std_msgs tf message_runtime geometry_msgs message_generation
  DEPENDS Boost
# let's use C++11
SET(CMAKE_CXX_FLAGS "-std=c++11 ${CMAKE_CXX_FLAGS}")
include_directories(
  include
  ${tf2_INCLUDE_DIRS}
  ${catkin_INCLUDE_DIRS}
  ${Boost_INCLUDE_DIRS}
# Costmap2D Layer plugin
add_library(RadarDataLayer lib/RadarDataLayer.cpp)
target_link_libraries(RadarDataLayer ${Boost_LIBRARIES} ${catkin_LIBRARIES})
Originally posted by 9a3eedi on ROS Answers with karma: 63 on 2017-08-01
Comment by gvdhoorn on 2017-08-01:
This is a (deferred) linker error, not a compilation issue.
Please post your CMakeLists.txt -- make sure to remove all the boilerplate comments from it first (lines starting with #).
Comment by 9a3eedi on 2017-08-01:
I think I may have found the problem. tf2_geometry_msgs only supports native transformations certain types of messages from geometry_msgs, and PolygonStamped isn't one of them, according to this link http://wiki.ros.org/tf2_geometry_msgs . I'm not sure yet so I'm going to try another type first.
I would expect to see a compiler error ("no candidates" or "no matching function call for ..") in that case, not a linker error. A 'missing symbol error' basically means that the compiler embedded the use of an external symbol in your library, but you didn't link against all needed dependencies.
Hi, I added my CMakeLists.
It turns out that tf2_geometry_msgs does not support transforming PolygonStamped!
I changed my code so that instead of transforming PolygonStamped, it would transform each individual Point in it (i.e. I was transforming PointStamped instead now). This seems to work fine and did not get any issues.
Originally posted by 9a3eedi with karma: 63 on 2017-08-09
Comment by gvdhoorn on 2017-08-09:
Ok. Thanks for reporting back.
Would it make sense to add the support and submit a pull request against tf2_geometry_msgs to get it merged upstream?
Comment by 9a3eedi on 2017-08-10:
I think it would make sense for convenience sake. I can imagine a lot of reasons why you'd want to do it.
Comment by gvdhoorn on 2017-08-10:
Seeing as you've already done it, would it be possible for you submit a PR? :)
