I want to publish messages to my robot in order to get it to move in the command line but I can't figure out how to format the rostopic pub /topic /type . I'm having issue with the data and how to find the format for it. I'll include a specific example below. Command Line Input:
$ rosmsg show gazebo_msgs/ModelStates
string[] name
geometry_msgs/Pose[] pose
  geometry_msgs/Point position
    float64 x
    float64 y
    float64 z
  geometry_msgs/Quaternion orientation
    float64 x
    float64 y
    float64 z
    float64 w
geometry_msgs/Twist[] twist
  geometry_msgs/Vector3 linear
    float64 x
    float64 y
    float64 z
  geometry_msgs/Vector3 angular
    float64 x
    float64 y
    float64 z
This is what I'm thinking. Someone please help!
rostopic pub -10 /gazebo/model_states gazebo_msgs/ModelStates '"Hello" [] [] [] []"
Originally posted by RichardVZ on ROS Answers with karma: 1 on 2023-06-16
This terminal command will show you high-level help with various options:
$ rostopic pub --help
Usage: rostopic pub /topic type [args...]
The [args...] syntax is a yaml dictionary, which is explained here: http://wiki.ros.org/ROS/YAMLCommandLine
Also, it's a bad idea to publish to some topics if some node is already publishing. You may seriously confuse the subscribers to that topic.
Originally posted by Mike Scheutzow with karma: 4903 on 2023-06-17
Comment by RichardVZ on 2023-06-20:
This page helps a lot. Thank you!
I think more clarification on what you exactly trying to achieve will be great.
But from what I understand if you have a problem with the message format on the terminal, when you use (rostopic pub), you can simply write
Then press TAB button on your keyboard it will autocomplete with the message format required then you can change it with the required values.
This will work! I didn't know that this was possible thank you.
