I was unsure about how to publish a message to joint_angles topic. These are the commands which I have run till now, all in different terminals:
roscore
~/naoqi/naoqi-sdk-1.12.5-linux32/naoqi --verbose --broker-ip 127.0.0.1
roslaunch nao_description nao_state_publisher.launch
roslaunch nao_driver nao_driver_sim.launch
rosrun rviz rviz
rostopic pub -1 /cmd_vel geometry_msgs/Twist '{linear: {x: 1.0, y: 0.0, z: 0.0}, angular: {x: 0.0, y: 0.0, z: 0.0}}'
After I run all these I can see the Nao model walking in the RViz window. What I wanted was to see different joint movements and I figured I'll have to publish a message to /joint_angles. So I tried this:
rostopic pub -1 /joint_angles nao_msgs/JointAnglesWithSpeed -- '' 'HeadYaw' 2.0 0.5 1
But I got an invalid msg_args error. So obviously I dont know how to publish a message. Any help on how to do that?
Originally posted by Karan Thakkar on ROS Answers with karma: 1 on 2012-09-14
I see that what you're trying to publish is a rather complex message type http://ros.org/doc/api/nao_msgs/html/msg/JointAnglesWithSpeed.html
I am not sure if you can publish a topic like this on the command line, since it has a header. However, ignoring the header, the next two arguments are arrays, so if this works:
rostopic pub -1 /joint_angles nao_msgs/JointAnglesWithSpeed -- '' ['HeadYaw'] [2.0] 0.5 1
If that doesn't work, take a look at this link and see if it helps : http://answers.ros.org/question/10244/publish-arrays-to-a-topic-on-the-command-line/
If those both do not work, then you might want to try writing a ROS node that publishes these messages instead.
Originally posted by dougbot01 with karma: 342 on 2012-09-16
Comment by Lorenz on 2012-09-16:
Just a note: you can fill in the header from the command line. See here.
