Hello,
I am working with navigation robot in obstacle situation, using navigation stack.
For the test, I put the robot, obstacle, target in the same line and see if it can avoid the obstacle and go to target, making a curve path.
As I anticipate, the navigation global path is made in a curve to avoid the obstacle. However, the local path does not follow the global path and make the robot get bumped to the obstacle while taking much time to escaping from it.
Is there any way to make the local path be aware of the global path?
Thanks in advance!!
Originally posted by mirakim on ROS Answers with karma: 21 on 2022-12-28
Comment by ljaniec on 2022-12-28:
What do you mean when you say that the robot does not follow the path? Is it not moving at all, or is it moving incorrectly?
Comment by mirakim on 2022-12-28:
@ljaniec Yes It moves incorrectly! And I figured out that the path I uploaded is global path while the local path keeps ignoring the obstacle. So I change the topic from 'robot does not follow path in collision' to 'local path ignores obstacle'.
@mirakim It would be helpful to see your YAML file with local planner configuration.
You can read more about parameters here: https://wiki.ros.org/base_local_planner?distro=melodic
If you are using TEB planner, check this: https://wiki.ros.org/teb_local_planner
If DW, the first link has a section about it.
The obstacles should be visible in the costmap, perhaps this piece of info is missing and is a source of error?
Originally posted by ljaniec with karma: 3064 on 2022-12-29
