I'm trying to find known techniques for keeping a manually controlled robot within a known polygon fence. More specifically, a pilot controls a robot by issuing desired velocity vectors, and the autopilot adjusts the velocity so that the distance to any boundary is always at least the stopping distance of the robot.
My goal is to implement a system that:
- Tries to follow the pilot's desired velocity as closely as possible.
- Is robust to changes in position and desired velocity. At a minimum, I want the velocity to change continuously with respect to the position of the robot and desired velocity of the pilot. Informally, this means that sufficiently small changes in the position or desired velocity of the pilot induce arbitrarily small changes in the velocity.
The second point is particularly important. Suppose that the policy were to find the intersection with the boundary in the direction of the desired velocity and slow down smoothly to that point. The below figure depicts a couple of scenarios in which this would not be continuous. In this figure, the black lines represent the fence boundary, the red dot is the position of the robot, and the blue line is the desired velocity of the pilot. In figure (a), a small perturbation of the position to the left will cause a large increase in allowed velocity because the desired velocity will intersect the far edge instead of the near edge. In figure (b), a small clockwise rotation of the velocity vector will result in a large decrease in allowed velocity because the desired velocity will intersect the near edge instead of the far edge.
I have searched for relevant papers, but most of the papers I've seen have dealt with fully autonomous obstacle avoidance. Moreover, I haven't seen any papers address the robustness/continuity of the system.
:EDIT:
The robot knows its own location and the location of the boundary at all times. I also have some equations for maximum velocity that allow a smooth ramp-down to a single line boundary (though I'd be interested in seeing a better one). I would like the velocity limits to be continuous in the position and desired velocity of the pilot.
I want to continuously throttle the user's input such that a minimum safe distance between the robot and the boundary is maintained, but see the figure that I added to the question. The hard part (I think) is to make sure that small changes in position (e.g. due to sensor noise) or small changes in desired velocity (e.g. due to pilot noise) don't cause huge changes in what the autopilot allows.
I want continuity because I think it will provide a much nicer experience for the pilot while still enforcing the fence boundary. There is a trade-off with optimally but I think this is worth it. Even though the physical world smoothes any discontinuities in velocity, big changes could still cause large jerk which will be somewhat disturbing to the pilot. The goal is to not have the autopilot introduce large oscillations not intended by the pilot.
This Will be implemented On a physical system that has sensors that provide an estimation of position, and the boundary shape is known and is unchanging. The actual system that I'm targeting is a quadcopter.
