Hi all,
I'm trying to run simple ros2 node inside blender environment.
The node should render some scenario and publish the frames to a topic using cv_bridge.
I tried to source /opt/ros/foxy/setup.bash and build a workspace in the scripts folder before running blender. After that, execute the node's script from blender, but It can't find the ros2 python packages and fails to run simple publisher node.
Any ideas of how I can get it to work?
Thanks in advance, Iftach.
Originally posted by Iftahnaf on ROS Answers with karma: 23 on 2021-11-10
Comment by gvdhoorn on 2021-11-10:
ROS 2 is Python 3 only. You've tagged this python2.7
, so that would appear not to work.
Comment by Iftahnaf on 2021-11-10:
Wrong tagget, my bad.
The blender environment's python version is 3.9
