I ran ros2 show interface sensor_msgs/msg/JointState to see how to publish using the command line AND python code. THis is the result:
^Cbwuk@robots:~/my_robot/my_robot_description$ rosinterface show sensor_msgs/msg/JointState
# This is a message that holds data to describe the state of a set of torque controlled joints.
# The state of each joint (revolute or prismatic) is defined by:
#  * the position of the joint (rad or m),
#  * the velocity of the joint (rad/s or m/s) and
#  * the effort that is applied in the joint (Nm or N).
# Each joint is uniquely identified by its name
# The header specifies the time at which the joint states were recorded. All the joint states
# in one message have to be recorded at the same time.
# This message consists of a multiple arrays, one for each part of the joint state.
# The goal is to make each of the fields optional. When e.g. your joints have no
# effort associated with them, you can leave the effort array empty.
# All arrays in this message should have the same size, or be empty.
# This is the only way to uniquely associate the joint name with the correct
# states.
std_msgs/Header header
string[] name
float64[] position
float64[] velocity
float64[] effort
As you can see it's using the array input.
I have no idea how to start that in python code or command line.
I tried to run like this; ros2 topic pub --once /joint_states sensor_msgs/msg/JointState '{name, "front_right_wheel", position: [0.0], velocity: [1.0], effort: [0.0]}' --once Obviously, it didn't work. I tried others as wel. No luck.
I couldn't find the ros2 document for it. I found a lot of documents on ROS1 however, I joined ROS2 so I have almost no knowledge on ROS1.
Originally posted by kak13 on ROS Answers with karma: 113 on 2021-08-25
Hello @kak13,
There are many mistakes in your command.
  1. {name, "front_right_wheel" : Name is not properly defined.
  2. --once : you are using this 2 times in your command.
  3. string[] name = you have to pass in list formate, I think you are passing a single string.
    ros2 topic pub --once /joint_states sensor_msgs/msg/JointState "{name: ['<your-name>'], position: [0.0], velocity: [1.0], effort: [0.0]}"
And If you want to take multiple data in your Array then
ros2 topic pub --once /joint_states sensor_msgs/msg/JointState "{name: ['<your-name>', '<your-second-name>'], position: [0.0, 0.4], velocity: [1.0, 1.2], effort: [0.0, 0.4]}"
Try this if you are having any issues feel free to drop commet. I think this should work.
Originally posted by Ranjit Kathiriya with karma: 1622 on 2021-08-26
Comment by kak13 on 2021-08-26:
Thank you so much for your time!
But the question I still have is that I wanted to run /joint_states, not cmd_vel.
Which is this;
bwuk@robots:~/my_robot/my_robot_description$ ros2 topic list
/clock
/joint_states
/parameter_events
/performance_metrics
/robot_description
/rosout
/tf
/tf_static
So, I checked what kind of data type does it use? I found out about this
bwuk@robots:~/my_robot/my_robot_description$ ros2 topic info /joint_states
Type: sensor_msgs/msg/JointState
Publisher count: 1
Subscription count: 1
So, I ran and see what kind of format does it use. The result is just as above to the post (characters limit reached btw)
Comment by Ranjit Kathiriya on 2021-08-26:\
But the question I still have is that I wanted to run /joint_states, not cmd_vel. Which is this;
I am sorry for the wrong answer, I have updated my answer please! have a look again.
Oohh!! It worked! Thank you so much!
I learned that ros2 pub doesn't make gazebo robot move T_T
THank you so much for your time, I'll mark your answer as a correct so others can learn from it as well too!
