System info
  • Operating System:
    • Docker + Ubuntu 20.04, 10th gen i7
    • Docker + Ubuntu 20.04, jetson AGX Xavier
  • ROS2 Version:
    • Foxy binaries
Steps to reproduce issue
Make sure the system is publishing transforms to /tf at 30Hz. Run a simple node with a TransformListener in python and in C++.
Python
import rclpy
from rclpy.node import Node
from tf2_ros.buffer import Buffer
from tf2_ros.transform_listener import TransformListener
class MyNode(Node):
    def __init__(
        self,
    ) -> None:
        super().__init__("navigation_god_node")
        self.buffer = Buffer()
        self.listener = TransformListener(
            buffer=self.buffer, node=self, spin_thread=False
        self.listener.buffer = self.buffer
        self.tm_main = self.create_timer(
            timer_period_sec=0.5,
            callback=self.timer_callback,
    def timer_callback(self):
        if  self.buffer.can_transform(
            "camera_color_optical_frame",
            "map",
            rclpy.time.Time(seconds=0, nanoseconds=0).to_msg(),
            self.get_logger().info("Can transform")
def main(args=None) -> None:
    rclpy.init(args=args)
    node = MyNode()
    rclpy.spin(node)
    node.destroy_node()
    rclpy.shutdown()
if __name__ == "__main__":
    main()
C++
#include <string>
#include "rclcpp/rclcpp.hpp"
#include "rclcpp/time.hpp"
#include <tf2_ros/buffer.h>
#include <tf2_ros/transform_listener.h>
#include "tf2_geometry_msgs/tf2_geometry_msgs.h"
using namespace std::chrono_literals;
using namespace std;
class MyNode : public rclcpp::Node
  public:
    MyNode(const string& node_name, const string& nm)
    : Node(node_name, nm)
      _buffer_tf2 = std::make_unique<tf2_ros::Buffer>(this->get_clock());
      _listener_tf2 = std::make_shared<tf2_ros::TransformListener>(*_buffer_tf2);
      timer_ = this->create_wall_timer(
      500ms, std::bind(&TFListenerNode::timer_callback, this));
  private:
    void timer_callback()
      if (_buffer_tf2->canTransform("camera_color_optical_frame", "map", tf2::TimePointZero))
            RCLCPP_INFO(this->get_logger(), "Can transform");
    rclcpp::TimerBase::SharedPtr timer_;
    std::unique_ptr<tf2_ros::Buffer> _buffer_tf2;
    std::shared_ptr<tf2_ros::TransformListener> _listener_tf2;
int main(int argc, char* argv[])
    rclcpp::init(argc, argv);
    auto tf_transforms_node = make_shared<MyNode>("listener_transforms_node", "tf_transforms");
    rclcpp::spin(tf_transforms_node);
    rclcpp::shutdown();
    return 0;
Expected behavior
Roughly the CPU load should be the same, at least not that big difference.
Actual behavior
The python implementation loads the CPU almost 10x. Tested in my beefy laptop and in a Jetson.
My laptop
Python node: ~8% CPU one core C++ node: ~1% CPU one core
Jetson
Python node: ~20% CPU one core C++ node: ~2% CPU one core
In this case, it makes the python API unusable in a constraint environment like a Jetson.
Does anyone know any known issue with tf2_ros in python? Does this implementation look bad?
Originally posted by charlie92 on ROS Answers with karma: 87 on 2021-06-29
I have not benchmarked this with rclpy but we saw the same behavior with rospy and roscpp where actually just subscribing to the /tf topic in python takes that order of magnitude CPU to receive the firehose of high frequency data.
To that end we created the tf2 buffer_server. It providea an action based API for querying transforms from another node. You can find some pointers in the tf2 MIgration notes: http://wiki.ros.org/tf2/Migration
The c++ implementation of the Listener be default provides this API. And you can just create the buffer_client and point it at an existing buffer_server running on a neighboring c++ node.
The ROS 2 implementation parallels the ROS 1 implementation.
Originally posted by tfoote with karma: 58457 on 2021-06-29
Comment by charlie92 on 2021-06-29:
Thank your for the information, I didn't know about this server and actually I was thinking on implementing a kind of buffer_server. I suppose we can just use this client in python https://github.com/ros2/geometry2/blob/ros2/tf2_ros_py/tf2_ros/buffer_client.py
