Hello there,
I am not able to decrease the speed of my real robot. If I am decreasing the speed from RVIZ by setting Velecoty Scaling and Accel Scaling then it is working fine. If I am giving the robot a trajectory from python code then it very fast does anyone have an idea of how can I be able to solve this issue?
I have tried few things:
  1. By using set_max_velocity_scaling_factor and set_max_acceleration_scaling_factor function as maintained in following post.
    move_group = moveit_commander.MoveGroupCommander(group_name) move_group.set_max_velocity_scaling_factor(0.01) move_group.set_max_acceleration_scaling_factor(0.01)
  2. I have updated default_velocity_scaling_factor and default_acceleration_scaling_factor to 0.01 in joint_limits.yaml file.
Originally posted by Ranjit Kathiriya on ROS Answers with karma: 1622 on 2021-04-15
in case of computeCartesianPath(..) there is no support for scaling velocities/accelerations. You can control the speed by using retime_trajectory(..):
        waypoints = getMyWaypoints()
        (plan, fraction) = group.compute_cartesian_path(
            waypoints,
            0.01,
            0.0
        plan = group.retime_trajectory(moveit_commander.RobotCommander().get_current_state(),
                                       plan,
                                       velocity_scaling_factor)
        group.execute(plan, wait=True)
Originally posted by crnewton with karma: 71 on 2021-04-15
Comment by Ranjit Kathiriya on 2021-04-15:
Thanks! it works
Comment by lorepieri on 2021-05-27:
moveit_robot_state = moveit_commander.RobotCommander().get_current_state()
Also speed is actually the speed scaling factor.
Comment by crnewton on 2021-05-31:
Updated my answer to be more generic. as @lorepieri commented.
Comment by robra on 2023-02-28:
Hi, do you know how to implement this in c++? I looked into the MoveGroupInterface class here here but couldn't find a retime_trajectory function
Comment by Jiang Zizhen on 2023-04-18:
retime_trajectory is only available in rospy, no corresponding function in cpp
Comment by robra on 2023-04-19:
Thanks, but just for reference, time parameterization can be implemented in c++ using the corresponding classes here and therefore the retime_trajectory is not needed in c++
Comment by Jiang Zizhen on 2023-04-19:
hi, how to use it, could you please give a template code!
