Hi,
I want to use the rclpy module in a python script. This script is called by a flask application which is invoked by an apache2 webserver and does not get the necessary bash context. When I run the python script from bash with python3 foo.py everything works fine, as I have . /opt/ros/foxy/setup.bash in my ~/.bashrc .
When the script gets invoked by flask and apache2, import rclpy is not found.
Exeucting sys.path.insert("/opt/ros/foxy/lib/python3.8/site-packages/")
brings another error:
The C extension '/opt/ros/foxy/lib/python3.8/site-packages/rclpy/_rclpy.cpython-38-x86_64-linux-gnu.so' failed to be imported while being present on the system. Please refer to 'https://index.ros.org/doc/ros2/Troubleshooting/Installation-Troubleshooting/#import-failing-even-with-library-present-on-the-system' for possible solutions
There has been a similar Thread with no solution. The essence seems to be that opt/ros/foxy/setup.bash does more than just setting paths.
Now, is there any possibilty to use rclpy in a python script without sourcing from bash? Thanks
Ubuntu 20.04
ROS2 foxy
Originally posted by highmax1234 on ROS Answers with karma: 98 on 2021-04-07
