Hello there,
I have successfully integrated real robots with moveIt. I can move at my given path with the plan & execute button, but if I press the Plan button and then it executes that plan. After, when I press the Execute button I am obtaining this error, and my robot doesn't move.
Guys any idea where I am doing a mistake?
[ERROR] [1617204711.965383782]:
Invalid Trajectory: start point deviates from current robot state more than 0.01 joint 'joint_a2': expected: -1.5708, current: -1.47654
I have checked the things which you maintained but then also I am not able to fix the solution.
When I am doing the plan and execute the first time it is working fine and from the second time I am getting Failed error. I am attaching a screenshot below.
image description
When I am pressing the plan & execute button I am getting the execution successful!
image description
Thanks for helping!
Originally posted by Ranjit Kathiriya on ROS Answers with karma: 1622 on 2021-03-31
Most likely, either
  • A) your start state is not at your current robot position when you start planning, or
  • B) the robot moved after you created the plan.
To set the start state before planning, try selecting the <current> option from the Start State dropdown menu in the Planning tab of the MotionPlanning plugin in Rviz. You can also visualize the start state by looking for the "Query Start" checkbox in the display widget.
Originally posted by fvd with karma: 2180 on 2021-04-04
Comment by Ranjit Kathiriya on 2021-04-06:
I have checked these steps and enhanced my question above. Thanks for replying!
Comment by Ranjit Kathiriya on 2021-04-07:
I don't know how but it started working. Might be Query Start helps
