I have the following in my CMakeLists.txt
project(robot)
add_library(${PROJECT_NAME} src/Robot.cpp)
ament_target_dependencies(${PROJECT_NAME} rclcpp)
add_executable(node src/node.cpp)
ament_target_dependencies(node ${PROJECT_NAME} ${PROJECT_NAME}_msgs rclcpp) # <--- this line
However, when compiling with colcon build, it gives the following error
ament_target_dependencies() the passed package name 'robot' was not found
for the highlighted line.
How do I let nodes use libraries that were compiled in the same package?
With ROS1 catkin, this was done with the following lines
add_dependencies(node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
target_link_libraries(node ${PROJECT_NAME} ${catkin_LIBRARIES})
which I assume is now combined into a single ament_target_dependencies()?
Originally posted by Rufus on ROS Answers with karma: 1083 on 2021-02-11
See this example on creating a library and using it in the same package.
In particular, note that for packages that aren't coming from find_package, e.g. locally compiled libraries in the same package, you will need to use target_link_libraries. See this answer.
In additon, make sure the libraries and packages are installed in the correct location, or else the node will not be able to find the library
install(
  TARGETS my_lib
  DESTINATION lib
install(
  TARGETS node
  DESTINATION lib/${PROJECT_NAME}
Originally posted by Rufus with karma: 1083 on 2021-02-12
