I'm a beginner about a migration. If you are familiar with migration from rosbuild to catkin, Could you teach me how to migrate from rosbuild to catkin. This is an example of eband_local_planner. I edited CMakeLists.txt as following. Is this correct? Now I use ROS hydro on Ubuntu12.04.
project(eband_local_planner)
# Before this can be catkinized, the control_toolbox needs to be catknized.
find_package(catkin REQUIRED
        COMPONENTS
                        roscpp
                        pluginlib
                        nav_core
                        costmap_2d
                        base_local_planner
                        nav_msgs
                        geometry_msgs
                        visualization_msgs
                        tf
                        tf_conversions
                        angles
                        control_toolbox
                        actionlib
                        eigen
find_package(Boost REQUIRED
    COMPONENTS
        thread
find_package(Eigen REQUIRED)
include_directories(
    include
    ${catkin_INCLUDE_DIRS}
${EIGEN_INCLUDE_DIRS}
add_library(eband_local_planner
  src/conversions_and_types.cpp
  src/eband_action.cpp
  src/eband_local_planner.cpp
  src/eband_local_planner_ros.cpp
  src/eband_trajectory_controller.cpp
  src/eband_visualization.cpp
target_link_libraries(eband_local_planner
    ${catkin_LIBRARIES}
${Boost_LIBRARIES}
install(TARGETS eband_local_planner
       LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
install(DIRECTORY include/${PROJECT_NAME}/
  DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
  PATTERN ".svn" EXCLUDE
install(FILES blp_plugin.xml
DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
package.xml is written on this web( https://github.com/ros-planning/navigation_experimental/tree/hydro-devel/eband_local_planner). If you have an experiment of catkinizing eband_local_planner, I want to know more information. The reason I put this article is I wanted to resolve an error when I moved a turtlebot with eband_local_planner. Actually, I have compiling error.
CMake Error at eband_local_planner/CMakeLists.txt:53 (install):
  install TARGETS given no LIBRARY DESTINATION for shared library target
  "eband_local_planner".
CMake Error at eband_local_planner/CMakeLists.txt:62 (install):
  install FILES given no DESTINATION!
Originally posted by Ken_in_JAPAN on ROS Answers with karma: 894 on 2014-05-21
Comment by Ken_in_JAPAN on 2014-05-21:
Before catkinizing a package, Is it better to rosbuild the package of fuerte version?
The master branch here is also catkinized, and this is the source repository: https://github.com/utexas-bwi/eband_local_planner
Originally posted by ahendrix with karma: 47576 on 2014-05-21
Thanks @ahendrix, Excuse me, may I ask you? does master mean stable?
Comment by ahendrix on 2014-05-21:
Branch names are set by the developer; you can usually guess which branches are stable by looking at all of the branch names, and how often they're updated: https://github.com/utexas-bwi/eband_local_planner/network . You can also look at tags, which are usually the released versions.
In this case, it looks like changes are done on their devel branch and on feature branches, and releases are done from master.
