The kinematics.yaml
contains default parameters and I would like to change for certain planning operations the solve_type
parameters.
I don't believe this will work. That file is only read once, during startup (of roslaunch
actually).
MoveIt instantiates the IK solver then once (well: depending on how many groups you have configured of course), which reads the parameters, once, and those get used until a new Trac IK instance is created.
This is the only time TRAC_IKKinematicsPlugin
(ie: the plugin class) reads that parameter: link.
So how to retrieve the IK solver pointer in order to change some parameters, and so that it is updated for the MoveGroupInterface?
Internally, Trac IK stores the value of that parameter in a private member variable called solve_type_
(here). There doesn't appear to be any setter (nor a getter) for that member variable.
So even with a reference to the IK solver's instance, you would not be able to change the value of that member variable.
Having written that: the plugin does check how it's been configured before solving a query (here).
So theoretically, you could add dynamic_reconfigure support to the MoveIt plugin, expose that solve_type_
member as a dynamic_reconfigure
variable, and then use dynamic_reconfigure
's service API to update the solve type dynamically. Note: you'd still need to add a setter though.
It would not be linked to any particular query though, as it wouldn't be part of the IK request. But it would allow you to change the solve type after the MoveIt IK plugin has been instantiated.
Edit:
I want to change this parameters in the code and without user intervention.
dynamic_reconfigure
has a service interface which is non-user-facing. It's exactly there to be used "from code". It does not require any user interaction.
Any advices about how could I maybe dynamically cast it to a "TRAC-IK solver" in oder to set this parameter?
Without creating that setter you'll not be able to change anything.
But if you're willing to do all sorts of nasty things, then:
- add the setter
- downcast the reference to the specific
- use the setter
It would be very brittle though, as you'd have to be sure what you have is actually an instance of TRAC_IKKinematicsPlugin
And using dynamic_cast
this way is not what most people consider proper use.
Originally posted by gvdhoorn with karma: 86574 on 2020-11-16
Comment by cv_ros_user on 2020-11-16:
Thanks for your answer.
I don't think dynamic_reconfigure
is an option for me. I want to change this parameters in the code and without user intervention. I would like to try something like move to a specific pose that should maximize the manipulability index and then use Cartesian plan with distance criterion for the IK solver.
I am already building MoveIt and TRAC-IK from sources. I have seen this line: const kinematics::KinematicsBaseConstPtr& solver = jmg->getSolverInstance();
(here). Any advices about how could I maybe dynamically cast it to a "TRAC-IK solver" in oder to set this parameter?
Thanks again.
I have almost no experience with dynamic_reconfigure
so I didn't know it was possible to use it with services. I will try to expose this parameter. The concept of plugin in MoveIt is a little bit hard to grasp for me. So I tend to avoid this path.
Comment by cv_ros_user on 2020-11-17:
So I have added a trac_ik/trac_ik_kinematics_plugin/cfg/TRACIKDynamicReconfigure.cfg
file. I have added a dynamic_reconfigure_server_
in trac_ik/trac_ik_kinematics_plugin/src/trac_ik_kinematics_plugin.cpp
When using rosrun rqt_reconfigure rqt_reconfigure
, change is correctly printed in TRAC_IKKinematicsPlugin::dynamicReconfigureCallback
But I have this kind of errors Tried to advertise a service that is already advertised in this node [/ik/trac_ik/set_parameters]
at initialisation. So in which files should I put the cfg
and the dynamic_reconfigure_server_
in order to update correctly the TRAC_IKKinematicsPlugin
