From the wiki :
latch [optional]
Enables "latching" on a connection.
When a connection is latched, the last
message published is saved and
automatically sent to any future
subscribers that connect. This is
useful for slow-changing to static
data like a map. Note that if there
are multiple publishers on the same
topic, instantiated in the same node,
then only the last published message
from that node will be sent, as
opposed to the last published message
from each publisher on that single
topic.
That means that if you publish a message with latch=true
then every subscriber will get the message once even if you don't publish it anymore. Your code is publishing in a while loop
so indeed it won't make a difference wether latch=true
or false
because you always send a new message. To show the difference you need to publish data only once (or several time but stop at some point) and then subscribe to the topic when it's not published anymore (with rostopic echo
for example). A code that would show the difference could be :
ros::init(argc,argv, "Pub");
ros::NodeHandle nh;
ros::Publisher pub_latch_true = nh.advertise<std_msgs::Int8>("topic_latch_true", 50, true);
ros::Publisher pub_latch_false = nh.advertise<std_msgs::Int8>("topic_latch_false", 50, false);
ros::Rate rate(1);
std_msgs::Int8 msg;
msg.data = 2;
pub_latch_true.publish(msg);
pub_latch_false.publish(msg);
while(ros::ok())
ros::spinOnce();
rate.sleep();
return 0;
Run this node (the while loop
is only to keep the node alive) and then do rostopic echo /topic_latch_true
and rostopic echo /topic_latch_false
, you won't have any output for topic_latch_false
and you will have only one message with topic_latch_true
(the last published message).
Originally posted by Delb with karma: 3907 on 2020-09-03
Comment by rjosodtssp on 2020-09-03:
thank you, very helpful
