Hi. I installed turtlebot 3 simulation. Now simulation of turtlebot is running on machine1:
roslaunch turtlebot3_fake turtlebot3_fake.launch
Environment variables were set before:
ROS_MASTER_URI
ROS_IP
Both pointing to IP of machine1.
On machine2 i want to start teleop to controll the bot. Environment variables were set so that Master is pointing to machine1.
The right master connection is shown after i started teleop.
roslaunch turtlebot3_teleop turtlebot3_teleop_key.launch
Teleop is running, no error shown. But nothing happens on machine1 when i hit some buttons (w,a,s,d) Robot moves if I use teleop on machine1.
RQT on machine2 seems to report correct connection and data e.g. velocity. Ping and ssh in both directions is fine.
Whats missing? Some tips? Thanks in advance for your support.
Update on details: Please find all details below:
machine1:
ip: 192.168.2.121
ROS_MASTER_URI=http://192.16.8.2.121:11311
ROS_IP=192.168.2.121
ROS_HOSTNAME not provided/set
simulation was launched:
machine2:
ip: 192.168.2.122
ROS_MASTER_URI=http://192.168.2.121:11311
ROS_IP=192.168.2.122
ROS_HOSTNAME=localhost (was set by apt-get installation or something else)
teleop was started: roslaunch turtlebot3_teleop turtlebot3_teleop_key.launch
rostopic echo on machine1 does not show anything unless I start teleop on machine 1.
During start of teleop on machine2 this log is printed on the terminal:
marco@ros-pi:~$ roslaunch turtlebot3_teleop turtlebot3_teleop_key.launch
... logging to /home/marco/.ros/log/ec0d656e-0ab1-11e8-adf6-247703a699e0/roslaunch-ros-pi-9040.log
Press Ctrl-C to interrupt
started roslaunch server http://localhost:35055/
SUMMARY
PARAMETERS
 * /rosdistro: kinetic
 * /rosversion: 1.12.12
NODES
    turtlebot3_teleop_keyboard (turtlebot3_teleop/turtlebot3_teleop_key)
process[turtlebot3_teleop_keyboard-1]: started with pid [9049]
Control Your Turtlebot3!
Moving around:
        w
   a    s    d
        x
w/x : increase/decrease linear velocity
a/d : increase/decrease angular velocity
space key, s : force stop
Originally posted by Boregard on ROS Answers with karma: 46 on 2018-02-04
Comment by gvdhoorn on 2018-02-11:\
This is almost never a good idea. I'd remove it.
That would seem doubtful, as those variables are not set by any (officical) ROS pkgs.
can you post an echo of your ROS_IP, MASTER_URI from both machines?
echo $ROS_MASTER_URI; echo $ROS_IP
my first assumtion would be that the ros_ip on machine 2 is not correct.
did you check if your teleop commands arrive at the correspondig topic?
rostopic echo <topic for command vel e.g. cmd_vel depends on installation>`
Originally posted by ski11io with karma: 46 on 2018-02-05
