Hi all,
below you can find my kinematics.yaml file. Since my robot only has 5 DoF and the IK solver has sometimes has probelms with finding solutions. So the position_only_ik parameter is set to true.
However, the ik-solver should at least try to find a solution according to the given 4D cartesian parameters (x,y,z,pitch). So I am wondering if I could use multiple kinematics solver or change the position_only_ik value online so that I can tell the robot: Use solver 1 with position_only_ik:false and if you failed use solver 2 with position_only_ik:true.
robot_arm:
kinematics_solver: trac_ik_kinematics_plugin/TRAC_IKKinematicsPlugin
kinematics_solver_search_resolution: 0.05
kinematics_solver_timeout: 0.005
position_only_ik: true
Originally posted by xman236 on ROS Answers with karma: 51 on 2020-08-06
