This might be a stupid question, but in the DWA planner, I've seen group of these three parameters which seems to be indicating the same thing to me.
My understanding: Minimum velocity in x direction is 0.1m/s let's say. Then by definition, that is also going to be the minimum translational velocity. For trans_stopped_vel, when I hover over the parameter in rqt_reconfigure, I see the definition on the lines of "Minimum velocity below which the robot is assumed to be not translating", which again seems to be saying the same thing to me.
If these three parameters actually mean the same thing, then it would be a waste to set them in thrice, so I'm assuming that there is a good reason they are not the same. Please enlighten me if that is the case and explain what each of them does.
Secondly, if I want the robot to be moving forward when possible and back off when it can't move forward but not prefer moving backwards otherwise, what values should I set these three parameters to?
Related third question: Is min_in_place_vel_theta parameter supported in kinetic and higher? I've seen some people mention it in previous answers, but I haven't noticed any difference by including/excluding it. And again, how are min_in_place_vel_theta
, rot_stopped_vel
and min_rot_vel different
This group of parameters which seems trivially different to me appears for minimum rotational velocity, max velocities as well.
I'm happy to read the paper on DWA if it needs more information to understand, and would be happy if someone can point me to some literature for in depth understand, but I also think it would be beneficial for me and others to know at least a short summary to get it working with the DWA algorithm still being abstract, because I think that's the true advantage of ROS.
Robot details: I have a non-holonomic two wheeled differential drive robot, with DC geared motors(175rpm, 8.4kgfcm)
Originally posted by parzival on ROS Answers with karma: 463 on 2020-07-10
