I'm trying to get a c++ action client example running. When I include the actions header, the console returns "no such file or directory". I'm guessing I did something wrong with the CMakeList.txt. I'm fairly new to ROS and CMake. Below is my console output, c++ action client code, and my CMakeList.txt files.
CMakeList.txt
project(demo_pkg2)
actionlib
actionlib_msgs
roscpp
std_msgs
message_generation
genmsg
add_service_files(
FILES
demo_srv.srv
add_action_files(
DIRECTORY action
FILES
demo_action.action
generate_messages(
DEPENDENCIES
actionlib_msgs
actionlib
std_msgs
catkin_package(
INCLUDE_DIRS include
LIBRARIES demo_pkg2
CATKIN_DEPENDS actionlib actionlib_msgs roscpp std_msgs
DEPENDS system_lib
message_runtime
include_directories(
include
${catkin_INCLUDE_DIRS}
add_executable(client src/client.cpp)
add_executable(server src/server.cpp)
add_executable(act_client src/act_client.cpp)
add_dependencies(client demo_pkg2_generate_messages_cpp)
add_dependencies(server demo_pkg2_generate_messages_cpp)
add_dependencies(act_client ${PROJECT_NAME}_EXPORTED_TARGETS)
target_link_libraries(client ${catkin_LIBRARIES})
target_link_libraries(server ${catkin_LIBRARIES})
target_link_libraries(act_client ${catkin_LIBRARIES})
project.xml
<?xml version="1.0"?>
<package format="2">
<name>demo_pkg2</name>
<version>0.0.0</version>
<description>The demo_pkg2 package</description>
<maintainer email="[email protected]">daniel</maintainer>
<license>TODO</license>
<build_depend>message_generation</build_depend>
<exec_depend>message_runtime</exec_depend>
<buildtool_depend>catkin</buildtool_depend>
<build_depend>actionlib</build_depend>
<build_depend>actionlib_msgs</build_depend>
<build_depend>roscpp</build_depend>
<build_depend>std_msgs</build_depend>
<build_export_depend>actionlib</build_export_depend>
<build_export_depend>actionlib_msgs</build_export_depend>
<build_export_depend>roscpp</build_export_depend>
<build_export_depend>std_msgs</build_export_depend>
<exec_depend>actionlib</exec_depend>
<exec_depend>actionlib_msgs</exec_depend>
<exec_depend>roscpp</exec_depend>
<exec_depend>std_msgs</exec_depend>
<export>
</export>
</package>
act_client.cpp
#include <ros/ros.h>
#include <actionlib/client/simple_action_client.h>
#include <actionlib/client/terminal_state.h>
#include <demo_pkg2/demo_action.h>
#include <iostream>
ros::init(argc,argv,"act_client");
//create action client
//true makes client spin its own thread
actionlib::SimpleActionClient<demo_pkg2::demo_action> ac("action_server",true);
ROS_INFO("Waiting for action server to start!");
ac.waitForServer();//wait forever fot the server to start
ROS_INFO("Actio server started, sending goal.");
//send goal to action
demo_pkg2::demo_actionGoal goal;
goal.order = 20; //set the goal
goal.sendGoal(goal); //send the goal to the server
//wait for the action to return
bool finished_before_timeout = ac.waitForResult(ros::Duration(30.0));
if(finshed_before_timeout)
actionlib::SimpleClientGoalState state = ac.goalState();
ROS_INFO("Action finished: %s",state.toString().c_str());
else
ROS_INFO("Action did not finish before the time out.");
//exit
return 0;
return 1;
console output
/home/daniel/catkin_ws/src/demo_pkg2/src/act_client.cpp:4:10: fatal error: demo_pkg2/demo_action.h: No such file or directory
compilation terminated.
demo_pkg2/CMakeFiles/act_client.dir/build.make:62: recipe for target ' demo_pkg2/CMakeFiles/act_client.dir/src/act_client.cpp.o' failed
make[2]: *** [demo_pkg2/CMakeFiles/act_client.dir/src/act_client.cpp.o] Error 1
CMakeFiles/Makefile2:1756: recipe for target 'demo_pkg2/CMakeFiles/act_client.dir/all' failed
make[1]: *** [demo_pkg2/CMakeFiles/act_client.dir/all] Error 2
Makefile:140: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j4 -l4" failed
Originally posted by ROSman on ROS Answers with karma: 3 on 2020-05-10
