I'm using:
ROS Melodic
ubuntu 18.04
Python 3.6.9
My ROS project name is "ros_moos" and my Python package name is "ros_moos".
My directory structure under ~/catkin_ws/src/ros_moos is:
├── CMakeLists.txt
├── launch
│   └── ros_moos.launch
├── LICENSE
├── msg
│   ├── AuvMove.msg
│   ├── AuvPose.msg
│   ├── AuvSafety.msg
│   └── AuvSystems.msg
├── nodes
│   ├── ros_moos
│   │   ├── auv_control.py
│   │   ├── auv_status.py
│   │   ├── __init__.py
│   │   ├── moos_ros.py
│   │   ├── moos_test.py
│   │   └── uuv_moos.py
│   └── tests
├── package.xml
├── params
│   └── auv_params.yaml
├── README.md
├── requirements.txt
└── setup.py
setup.py contains:
from setuptools import setup
from catkin_pkg.python_setup import generate_distutils_setup
setup_args = generate_distutils_setup(
    version="0.0.1",
    packages=['ros_moos'],
    package_dir={'': 'src'})
setup(**setup_args)
In the CMakeLists.txt I have catkin_python_setup() enabled. I build the project with "catkin_make -DPYTHON_EXECUTABLE=/usr/bin/python3" and there are no errors.
roslaunch can find my ROS package and start my two Python nodes, auv_control.py and auv_status.py. rostopic and rosmsg can find the definitions for AuvPose and the other messages.
The problem is the other Python modules, moos_ros.py and uuv_moos.py are NOT installed into the /devel/ environment and auv_status.py can't import those modules when started by roslaunch.
According to https://docs.ros.org/api/catkin/html/howto/format2/installing_python.html#modules and https://docs.ros.org/api/catkin/html/user_guide/setup_dot_py.html I've done what's required.
Is this a known issue or need I do something more?
Originally posted by billmania on ROS Answers with karma: 266 on 2020-05-01
Thanks to a nudge and some suggestions from Jarvis Schultz I found the problem with my setup. In my definition of the package_dir argument in setup.py, I incorrectly put 'src'. Since my nodes and their supporting Python modules are in "nodes" and not in "src", an update to that argument solved the problem.
After the correction, I verified that I can import moos_ros.py and uuv_moos.py in both the devel and the install environments.
Originally posted by billmania with karma: 266 on 2020-05-04
