It is possible to use under ros melodic gmapping?
Thanks,
Henne
Originally posted by Henne on ROS Answers with karma: 33 on 2019-07-09
Thanks,
Henne
To check the status of gmapping in ROS Melodic, see #q303253 (the procedure, not necessarily the answer itself of course).
For building it yourself from sources, see #q300480.
Originally posted by gvdhoorn with karma: 86574 on 2019-07-09
Comment by mgruhler on 2019-07-09:
I agree with the answer by @gvdhoorn
As I've just stumbled upon this: gmapping has been released into melodic two days ago. So it should be available with the next sync...
Comment by gvdhoorn on 2019-07-09:
@mgruhler: I've just updated #q300480. Not all of gmapping
has been released, but it most likely will be (ref the referenced issue).
@gvdhoorn: you are correct. I missed that the link to the rosdistro
PR from ros-perception/slam_gmapping
is actually pointing to the PR for ros-perception/openslam_gmapping
