I'm wondering about the proper way to get Qt 5 for ROS melodic on Ubuntu 18.04. I searched for hours but couldn't find any recent tutorials. Last year, I developed this package where I used catkin_create_qt_pkg with qt_create and depending on qt_build and libqt4-dev. Since these packages are not available for ROS melodic, I can not compile the package anymore.
I've found and installed the following package: qt_gui, but without any hint what it does. I assume the qt_gui_cpp package installs Qt 5 and creates the bindings. Can someone give me an overview of what is needed and what these packages do? Is there a recent example for the package.xml and CMakeLists out there? I assume the source code is the same.
I installed the ROS Qt Creator Plug-in 4.9.2, but I assume this does just install a "ROS-ready" IDE without any Qt libraries, right?
I'm also wondering about the differences between ros-melodic-qt-gui, ros-melodic-libqt and ros-melodic-qt.
Originally posted by prex on ROS Answers with karma: 151 on 2019-11-07
Needed to make some changes to make the old Qt4 ROS Kinetic GUI compile with Qt5 ROS Melodic. These were:
It's now using only "non-ROS" Qt libraries.
I made a package template here: https://github.com/jstiefel/qt5_ros_melodic_gui
Originally posted by prex with karma: 151 on 2019-11-08
Comment by PanMav on 2020-02-20:
Thank you very much! Using the CMake.txt file from your Github repo help us a lot!
I have create this template. Hope that will help. https://github.com/alexspirou/ROS_Melodic_Qt_GUI_Template
Originally posted by alexspi13 with karma: 36 on 2021-03-22
