Hello, I'm new to ROS and I'm having a problem when I try to move my turtle to a goal that I'm publishing. I created a node that subscribes to 2 topics: the position of the turtle and the goal_position. The goal_position topic is being published in the terminal. The node also publishes the velocity of the turtle. The purpose of this node is that when the turtle arrives at the goal position, it will then go to the following goal. I tried to this code in python without using class in the following code, however I received the error:
NameError: global name 'goal_pose' is not defined
NameError: global name 'pose' is not defined
What I don't understand is that I've defined them both.
#!/usr/bin/env python
import rospy
from geometry_msgs.msg import Twist
from turtlesim.msg import Pose
from math import po`enter code here`w, atan2, sqrt
import angles, math
goal = False
def update_pose(data):
global pose
pose = data
pose.x = round(pose.x, 4)
pose.y = round(pose.y, 4)
def update_goal(data1):
global goal_pose
goal_pose = data1
goal_pose.x = round(goal_pose.x, 4)
goal_pose.y = round(goal_pose.y, 4)
def turtleWalk():
global pose,pub,vel_msg,goal_pose,goal
linear_gain = 4
angular_gain = 12
distance_tolerance = 0.1
vel_msg = Twist()
while not goal:
distance = round(sqrt(pow((goal_pose.x - pose.x), 2) + pow((goal_pose.y - pose.y), 2)), 3)
linear_vel = linear_gain*distance
steering_angle = round(atan2(goal_pose.y - pose.y, goal_pose.x - pose.x),4)
angular_vel = angular_gain*(angles.shortest_angular_distance(pose.theta,steering_angle))
while distance >= distance_tolerance:
vel_msg.linear.x = linear_vel
vel_msg.angular.z = angular_vel
pub.publish(vel_msg)
goal = True
def turtleController():
global pub,vel_msg,goal_pose,pose
rospy.init_node('turtle_controller',anonymous=True)
pub = rospy.Publisher('/turtle1/cmd_vel',Twist,queue_size=10)
rospy.Subscriber('/turtle1/pose',Pose,update_pose)
rospy.Subscriber('/goal',Pose,update_goal)
rate = rospy.Rate(10)
turtleWalk()
rate.sleep()
vel_msg.linear.x = 0
vel_msg.angular.z = 0
if __name__ == '__main__':
try:
turtleController()
except rospy.ROSInterruptException:
pass
The error happens in line 31 which is :
Originally posted by Gi99 on ROS Answers with karma: 5 on 2019-05-21
Comment by gvdhoorn on 2019-05-21:
Don't paraphrase error messages. Copy-paste the exact and complete error message into your question.
Line nrs are important here, and the backtrace you get from Python would show us those.
Comment by Gi99 on 2019-05-21:
Thanks!! I put rospy.sleep(10.) and it worked!
Comment by jayess on 2019-05-21:
@Gi99 perhaps you can put your solution as an answer and accept it?
