Hi
I was running "hector_quadrotor_demo outdoor_flight_gazebo.launch". And I build a publisher "auto_fly", to publish message to control the quadrotor. The code is showed below:
#!/usr/bin/env python
import rospy from geometry_msgs.msg import Twist
def auto_fly(): pub= rospy.Publisher('/uav/uav2/cmd_vel',Twist,queue_size=10) rospy.init_node('auto_fly',anonymous=True) r=rospy.Rate(10) # 10Hz
while not rospy.is_shutdown(): pub.publish['x=0,y=1,z=0.2' 'x=0,y=0,z=0'] r.sleep(1.0)
if name== 'main': try: auto_fly() except rospy.ROSInterruptException: pass
When I run it, it shows,
TypeError: 'instancemethod' object has no attribute 'getitem'
What does this error mean and how to fix it?
Thanks a lot Glen
Originally posted by Glen on ROS Answers with karma: 40 on 2014-07-16
This error: TypeError: 'instancemethod' object has no attribute '__getitem__' means that you're trying to use square brackets ( getitem ) on something that doesn't support them; namely a method.
For the publish method call, you should be using parentheses, just like any other method call in python. You'll also need to revise the argument to your publish call; it should be a python message object:
msg = Twist() # create a new Twist message object
msg.linear.y = 1 # set the linear y component to 1
pub.publish(msg) # publish your message
Originally posted by ahendrix with karma: 47576 on 2014-07-17
Comment by Glen on 2014-07-17:
It works now, thanks a lot!
