I have a publisher in a package publishing a custom message type custom_gps.msg
of the following format
Header header
float64 latitude #degree
float64 longitude #degree
float32 altitude #WGS 84 reference ellipsoid fused by barometer
uint16 visibleSatelliteNumber #number of visible satellites
The message is published as drone_sdk/custom_gps
. I'm trying to subscribe to the message in another package using a callback. In my class, I declare the callback and I add the header file generated by ROS for the custom message type
#include <drone_sdk/custom_gps.h>
//Declare Class
void fused_gps_callback(const drone_sdk::custom_gps::ConstPtr& msg);
but when I try to implement the subscriber:
void FlightControl::fused_gps_callback(const drone_sdk::custom_gps::ConstPtr& msg)
// collect data here
I get the following error:
error: ‘custom_gps’ in namespace ‘drone_sdk’ does not name a type
My publisher works fine and I can see an output on rostopic echo
. Also in my CMakeLists
file, I believe I've added the dependency
using the following line: add_dependencies(flight_planner drone_sdk_generate_messages_cpp)
Here's what my CMAKE file looks like:
project(dji_flight_planner)
## Compile as C++11, supported in ROS Kinetic and newer
# add_compile_options(-std=c++11)
## Find catkin macros and libraries
## if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz)
## is used, also find other catkin packages
drone_sdk
nav_msgs
roscpp
rospy
std_msgs
sensor_msgs
geometry_msgs
find_package(DJIOSDK REQUIRED)
find_package(Eigen3 REQUIRED)
catkin_package(
INCLUDE_DIRS include
CATKIN_DEPENDS
#message_runtime
geometry_msgs
nav_msgs
std_msgs
## System dependencies are found with CMake's conventions
# find_package(Boost REQUIRED COMPONENTS system)
set(CMAKE_CXX_FLAGS "-std=c++11 ${CMAKE_CXX_FLAGS}")
include_directories(
# include
${catkin_INCLUDE_DIRS}
include ${EIGEN3_INCLUDE_DIR}
add_executable(drone_flight_planner src/flight_control.cpp src/flight_planner.cpp src/mobile_comm.cpp src/PID.cpp)
target_link_libraries(drone_flight_planner
${catkin_LIBRARIES}
${EIGEN_LIBRARIES}
${DJIOSDK_LIBRARIES}
add_dependencies(drone_flight_planner drone_sdk_generate_messages_cpp)
${catkin_LIBRARIES}
install(DIRECTORY launch
DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}/launch
Unfortunately, I can't use NavSatFix
due to the additional field visibleSatelliteNumber
in the message. Can anyone kindly point out what I'm doing wrong here?
Originally posted by marinePhD on ROS Answers with karma: 40 on 2019-03-15
